I have an image of a DOS disk which had bad sectors on it and it does not mount. I imaged it with ddrescue, Photorec discovered 2 partitions on the image and has recovered many files including custom image files (set up in photorec.sig) and many .exe files but only windows exe files. Is there a different signature required for DOS exe files? I see in the log many of the expected filenames but if I launch any recovered files they are windows executables. If I run testdisk on the same image it does not show any files.
Also, is there a way to tie up the filenames in the log to the recovered fnnnnnnn.exe files?
Any help much appreciated.
Recovering DOS Executables
Re: Recovering DOS Executables
The "MZ" signature alone generates too many false positives. It's why only Win PE or DOS with COFF extension are recovered by PhotoRec.
If you really want those files, create a photorec.sig file with
exe 0 "MZ"-
DaveJohnstone
Unfortunately, there does not seem to be any other identifier for nailing a DOS executable so I did create the simple MZ signature earlier and ran Photorec again. This signature has given me a further 73 files to try after I manually exclude ones with "This program requires Microsoft Windows" or "This program cannot be run in DOS mode". Is there a way to perform a second check with the above strings in a .sig file?
As to my second question, is there a way to equate the recovered filename to the log? What does the 1st column tell me? Basically, is there a relationship between the log:
Regards,
Dave.
And my filenames fnnnnnnn.xxx (obviously, these aren't the files I need - just an extract from the log)?blocksize=32768, offset=12288
Elapsed time 0h00m00s
Pass 1 (blocksize=32768) STATUS_EXT2_OFF
* 24-599: (null)
600-5015: fat
5016-5783: exe
5784-9367: exe
9368-9431: exe
9432-10071: exe
10072-10391: exe
10392-10455: exe
10456-13591: exe
13592-13719: exe
13720-4999575: exe
4999552 sectors contains unknown data, 10 invalid files found and rejected.
Sector 600
2 drwxr-xr-x 0 0 0 20-Feb-1998 06:18 .
0 drwxr-xr-x 0 0 0 20-Feb-1998 06:18 ..
1400 -rwxr-xr-x 0 0 11208 31-May-1994 15:52 ATTRIB.EXE
1401 -rwxr-xr-x 0 0 12241 31-May-1994 15:52 CHKDSK.EXE
1402 -rwxr-xr-x 0 0 26936 31-May-1994 15:52 COUNTRY.SYS
12 -rwxr-xr-x 0 0 15920 31-May-1994 15:52 COUNTRY.TXT
1403 -rwxr-xr-x 0 0 15718 31-May-1994 15:52 DEBUG.EXE
14 -rwxr-xr-x 0 0 3114 31-May-1994 15:52 DOSSETUP.INI
1404 -rwxr-xr-x 0 0 66294 31-May-1994 15:52 DRVSPACE.BIN
1407 -rwxr-xr-x 0 0 413 31-May-1994 15:52 EDIT.COM
Regards,
Dave.
