Not sure what I should be doing next
kevingeorge1430
#1 Post by kevingeorge1430 »
So I have Seagate 1tb Unallocated issue, so can't format. I've given up trying to recover the data but maybe later i will try
my main goal is for the HD to be usable.
After I clicked on analyze, it wasnt able to find any partition, so I clicked deep scan took a while and this is what I got
I'm not sure what to select. As of right now I left it on that screen
please help. Thank you in advance
Re: Not sure what I should be doing next
Looks like the key 'a' to manually add a partition has been pressed. To exit this screen, press Done.
