Error size boot_sector. Help!!!
Nemo90
#1 Post by Nemo90 »
Good afternoon.
He did the correct analysis of the hard drive, but the boot system is broken. I get this fault.
Error: size boot_sector 7813965824 > partition 4294967295
TestDisk 7.1-WIP, Data Recovery Utility, April 2018
        Disk /dev/sde - 4000 GB / 3725 GiB - CHS 486397 255 63
 1 * HPFS - NTFS              0  32 33 267349 121 35 4294967295
Status: Bad
Status: Bad
        Sectors are not identical.
        >[  Quit  ]  [Rebuild BS]  [  Dump  ]
                            Return to Advanced menu
Has anyone missed this error?
Thank you very much
Re: Error size boot_sector. Help!!!
Was your disk part of a Raid0 setup ?
If it was not the case, try RebuildBS, List and if you can see your files, choose Write, confirm, Quit
Nemo90
#3 Post by Nemo90 »
I have tried RebuildBS, List and I can see my files. But it does not leave me Write. The operation fails.
Thank you very much.
