Recovering files from E01 Image
liam2018
#1 Post by liam2018 »
I'd be grateful for any help or advice -
I have an E01 image created with FTK imager of a small FAT32 USB device. I am trying to work out the command line (scripted run) to use PhotoRec to search for all image files and copy them to a folder outside of the E01.
I am currently using the following .bat file command:
"C:\Users\Admin\Desktop\E01\photorec\Release\photorec.exe" /debug /log /d "C:\Users\Admin\Desktop\E01\Result" /cmd "C:\Users\Admin\Desktop\E01\test.E01" search,jpg,enable
However, when I run this, it appears to start, but the only output I get is a folder called 'Result.1' which contains a smaller E01 file, and an XML file called 'report.xml'.
Could anyone please advice me what i'm doing wrong please? Ideally i'm looking for a command to search E01 for any images, and copy to a separate folder without having to specify the partition type inside of the E01 etc.
Thank you in advance for any advice.
Re: Recovering files from E01 Image
The image file is split in several files, you should use
"C:\Users\Admin\Desktop\E01\photorec\Release\photorec.exe" /debug /log /d "C:\Users\Admin\Desktop\E01\Result" /cmd "C:\Users\Admin\Desktop\E01\test.E*" search,jpg,enable
