When I recover gz files from my disk, I found the length of the recovered files is not correct,the end of the file is filled with a lot of zero.How could
correct the file length?
Thanks a log.
gz file recovery
Re: gz file recovery
You can try to recompress the files, something like
But usually junk data at the end of the gz file isn't a real problem.
zcat file.gz|gzip - > new_file.gz
