hama microSD undelete
Sters
#1 Post by Sters »
Hello all, i hope someone can help me.
I have a hama micro sd HC 32GB, "4"-Speed.
It was in a android handy and it doesnt get realised, not in handy not in any pc.
I doesnt wanted to click everywhere because the data is very important.
Tryed the scan for "INTEL"
The normal scan didnt worked...the deeper scan shows not much more:
At the end of the deeper scan thi
Something gets resolved because about 2GB data is on the micro sd... and testdisk shows me 31 GB / 29 GB. but i dont know how to undelete the files.
With a harddisk testdisk worked great some time ago and i hope someone has some tipps for me...
Re: hama microSD undelete
Try PhotoRec instead, you may have better results.
