I'm learning about PhotoRec. I have known that Photorec uses file structure-based carving. Would you show me which algorithm is used in Photorec to search signature header/footer of file?
Looking forward to your response.
Thank you very much.
Algothrim in Photorec
Re: Algothrim in Photorec
To learn about how PhotoRec algorithms, you can read
- https://www.cgsecurity.org/wiki/PhotoRe ... oRec_works
- https://www.cgsecurity.org/wiki/Developers
Many thanks for your help. I've read these documents. In my opinion, to identify the file type, I need to find the corresponding header / footer, (carving data techniques), but the document does not specify which algorithm to search for strings, how to find single string or multiple strings.
Look forward to your help. Thank you!
