Ran Checkdsk now drive showing as RAW
benryder
#1 Post by benryder »
My external USB HD was showing that it needed Checkdsk running in Event Viewer. I ran and Windows prompted me to demount the drive, which I did.
The drive is now showing as RAW within Disk Management and isn't accessable within Windows.
Test Disk is able to see a Partition, however when you press P to list files it shows the message:
"Can't open filesystem. Filesystem seems damaged."
Log attached. Is there anything I can do to rescue my drive? Files?
Thanks.
Ben.
Thu Jul 5 12:08:16 2012
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=60022480896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=400088457216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=60022480896
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=400088457216
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=320072933376
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500107862016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=60019441664
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=320070483968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=400085812224
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=500096991744
file_pread(4,1,buffer,117242369(7297/254/63)) lseek err Invalid argument
file_pread(5,1,buffer,781433729(48641/254/63)) lseek err Invalid argument
file_pread(6,1,buffer,625153409(38913/254/63)) lseek err Invalid argument
file_pread(7,1,buffer,976784129(60801/254/63)) lseek err Invalid argument
Disk /dev/sda - 60 GB / 55 GiB - CHS 7297 255 63, sector size=512 - OCZ-AGILITY3, S/N:434f2d5a59315245543430334b53363535424345, FW:2.22
Disk /dev/sdb - 400 GB / 372 GiB - CHS 48641 255 63, sector size=512 - FUJITSU MHZ2400BT G1, S/N:2020202020202020374b30303854323856354256, FW:0000000C
Disk /dev/sdc - 320 GB / 298 GiB - CHS 38913 255 63, sector size=512 - ST3320418AS, S/N:2020202020202020202020205639434d42595435, FW:CC38
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WD 5000AAV External, S/N:WD-WCAUK0446681, FW:1.75
Disk /dev/sdd - 500 GB / 465 GiB - WD 5000AAV External
Analyse Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63
NTFS at 0/1/1
1 * HPFS - NTFS 0 1 1 60799 254 63 976751937
$MFT has invalid magic.
ntfs_mft_load(): Failed.
