Everything works fine upto last part
bbarbaros
#1 Post by bbarbaros »
I have WD external usb hdd
Test disk and other programs I tried can find my damaged partition.
Size is correct, folders are there
I do to the last part "write", reboot the computer and still the same. RAW drive
What else can I do?
Re: Everything works fine upto last part
Try what is described in https://www.cgsecurity.org/testdisk.pdf chapter "Repairing filesystem"
Good luck
