Recover Drive or Data after Storage Pool broken
RaymondLC92
#1 Post by RaymondLC92 »
I'm attempting to recover ~2-3TB of my data (primarily in Acronis .tib files).
The files were in a simple storage pool consisting of 2TB drives (with one set to be the mirror).
The disks in question have odd partitioning (I don't know if they were always like this):
I'm presently running QPhotoRec looking for the missing .tib and .7z files (either of which would be enough to return my data to me).
Any suggestions on recovering the data or the disk partitions would be hugely helpful.
Re: Recover Drive or Data after Storage Pool broken
Looks like two 3.7/4TB disks. PC Intel partition are limited to 2 TB. EFI GPT can handle disk over 2 TB.
If the original files were fragmented, it will not be possible to open the recovered tib files.
