I have a dual boot system of Windows7 and Fedora linux. I have multiple partitions formatted as NTFS so that data can be shared between OS's
Now my problem, I was quite confidently using gparted to move and resize one of these partitions --- then there was a power cut, leaving me with an apparently "stuffed" partition, (yes I should have done a backup!)
Both Windows and linux recognise that the partition exists but none of the basic OS recovery tools have helped.
I'm assuming that in the right hands data could be recovered, but this is beyond my current competence. Is there anybody here that can help?
Can I recover from this? Topic is solved
Re: Can I recover from this?
TestDisk works Intel and Microssoft Standard.
If you use a Bootmanager it might be possible that TestDisk overwrites thoose settings and you have to reinstall it.
I would need infos from TestDisk Analyse.
It's your current partition table.
From Quick and if your partition is not found from Deeper Search also.
If a partition is found, please check it and press p to have a try to list your files.
Hi Fiona
I have run Testdisk using the Deeper search and have found seemingly most if not all of the files that were in that partition. However I am uncertain how to proceed. I am reluctant to allow any writes to the disk that holds the lost partition.
Ideally I would like to copy anything I can to another spare partion. Is this the best way to proceed? I have attached the testdisk log with the hope you can provide some pointers
Phil
Phil
- log.bz2
- Testdisk log
- (4 KiB) Downloaded 965 times
Yes, you can use TestDisk to copy your data first.
Afterwards you can try to recover your partition directly.
If you list your files, at the bottom of the screen you see all the commands.
First of all you should check all files, folder where you want to copy.
If you mark that 2 dots in the upper area of the screen and hit enter, you'll get a directory up until you get to your disk selection.
You can select your desired disk and if you want to go into any previously created folder for your backup, you can use your right arrow key.
If you're done, please let me know.
You can have a try to restore your partition directly.
Infos will follow.
Would need some more infos about fedora.
Infos will follow.
Hi
Just to let you know I have recovered everything of importance from the corrupt partition. What an incredibly useful tool.
I must admit that I found the documentation a bit bewildering, but after reading them carefully several times things did become clear. Once I'd got the data safe, I just flattened and rebuilt the partition using linux fdisk and mkfs. I've just got some sorting out to do getting files back in the right place, but that's trivial.
The data recovered was so valuable, I was going to send the drive away to get it professionally recovered, so this has saved me a fortune.
Oh and I've bought a new 1Tb drive to do backups in future. I've just learned the hard way.
Thanks very much for your help.
Phil
Phil
Thanks for your feedback!
I'll set your topic as solved!
