No way to specify approx. partition positions for Deep Search?
VADemon
#1 Post by VADemon »
I'm in the process of recovering the partition table after it was completely wiped on the HDD. I was wondering why is there no way to specify approximate positions (start/end) of the partitions to speed up the process of Deeper Search?
I have a 2TB HDD and I know that the first partition was ~1.2 TB in size, where the last and the penultimate partitions were. In the end, it'd be possible to ±calculate all partition positions. So given the option, it's possible to at least reduce the search space by 1 TB/50% (for the end of the first partition, because it's start was completely wiped), then one could've selected the approximate ranges/sizes for the other partitions to look for.
Anyway, thanks for the software, I've just started and hope I'll be able to recover my wiped partition table and data of the first partially overwritten partition with TestDisk :)
Re: No way to specify approx. partition positions for Deep Search?
During Deeper Search, you can press 'F' (Capital F) to skip over the last partition found.
VADemon
#3 Post by VADemon »
Thanks, I will keep it in mind for the next time (hopefully not). And it's not in the testdisk.pdf manual. My suggestion would be to have a kind of an "S" key to skip, say 5 GB per single press.
