Good, I write with the hope of help, I have 2 discs on my pc and the largest of three teras was corrupted I do not know why, this is divided into three partitions, call 1, 2, 3, get back the 2 and the 3 which I intend to endorse the other disk but scandisk refuses to recover the 1 claiming that the file table is corrupt, I have dealt with other programs but I could not, if I try to access it, it tells me to format it, it has a tera that partition, I can not find the way to recover it and I do not know if there are other more powerful tools, I have used MiniTool Partition lite, partition magic, the hiren I have not tried yet another one called EaseUS, you can help me ... thanks
I attached what to testdisk took more than three days to perform, I am wrong with the record, it is 3 Teras but it comes out as a much smaller one.
Should I give partition 1 for lost?
Something else that can be done to recover that partition
Thanks in advance
https://ibb.co/9qh2Phy
GPT Partition Inaccessible
Re: GPT Partition Inaccessible
Run TestDisk, Advanced, select the partition "2" (your first NTFS partition), Boot, RebuildBS, List.
If you can see your files, choose Write, confirm, Quit and restart your computer.
Please post the testdisk.log file content if it doesn't work.
hi
I hope I was not wrong, (I do not speak English use a translator)
Fri Dec 7 02:12:45 2018
TestDisk 7.1-WIP, Data Recovery Utility, September 2018
Compiler: GCC 6.4, Cygwin32 2009.0
$MFT has invalid magic.
ntfs_mft_load(): Failed.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398931968
filewin32_getfilesize(\\.\PhysicalDrive2) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\PhysicalDrive2) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398931968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=108146982912
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=977272832000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=977272832000
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=1045910519808
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=199231651328
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=180036662784
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\I:)=7213154304
filewin32_getfilesize(\\.\J:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\J:) SetFilePointer err Función incorrecta.
filewin32_getfilesize(\\.\K:) GetFileSize err Función incorrecta.
filewin32_setfilepointer(\\.\K:) SetFilePointer err Función incorrecta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\L:)=5367660544
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\M:)=0
Warning: can't get size for \\.\M:
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\N:)=2000396746752
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD50 00AAKS-00A7B, S/N:WD-WCASY5417993, FW:01.0
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30 PURX-64P6ZY0, S/N:WD-WCC4N4CKP5S8, FW:80.0
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - TOSHIBA External USB 3.0, S/N:20180919011107F, FW:5438
Disk /dev/sdb - 3000 GB / 2794 GiB - WDC WD30 PURX-64P6ZY0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
2 P MS Data 264192 1909000191 1908736000 [Basic data partition] [210916-1]
NTFS, blocksize=4096, 977 GB / 910 GiB
3 P MS Data 1909000192 3817736191 1908736000 [Basic data partition] [210916-2]
4 P MS Data 3817736192 5860530175 2042793984 [Basic data partition] [210916-3]
NTFS, blocksize=4096, 1045 GB / 974 GiB
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
For some time now I have been waiting for an answer from this thread, apparently I can not recover anything because nobody tells me anything, but can I format that partition? If so, what program? , Normal Format or Low Level? , Someone who responds thanks
