Analyse Cylinder jumps from 01% to 99% and then Hangs
Izakoe
#1 Post by Izakoe »
So I have a few problems. I'm sure this is user error, as I am very grateful for your help and support and WONDERFUL software. Firstly, I ran both 7.0 and 7.1 and it detected the drive as EFI GPT. I ran both programs as EFI GPT, and each time It would jump from about 51/364800: 00% to 364801/364800: 099% and seem to hang.
I'm currently trying to run it as Intel/PC as I saw this user: viewtopic.php?t=6085 did the same.
TestDisk 7.1-WIP, Data Recovery Utility, December 2018
The harddisk (3000 GB / 2794 GiB) seems too small! (< 6001 GB / 5588 GiB)
HPFS - NTFS 267613 246 7 444571 7 56 2842815263
> FAT12 278704 174 41 457285 174 21 2868903746
FAT16 >32M 311123 136 8 481467 19 1 2736568983
HPFS - NTFS 364801 66 1 729586 18 31 5860268032
FAT16 <32M 375333 191 26 642679 139 23 4294910212
FAT16 <32M 392124 19 22 392132 160 29 137411
[ Continue ]
1468 GB / 1367 GiB
Does this mean all my data is... gone then?
I don't need all the files on this 3TB, as it is full. I only need a few gigs of essential documents.
Re: Analyse Cylinder jumps from 01% to 99% and then Hangs
What happen if you press the Enter key on this screen ?
Izakoe
#3 Post by Izakoe »
I figured it out. The Program auto-selected the EDI, when I needed to select the Intel/PC
