Usb not accessible because of I/O device error
Post Reply
Gloria8733
#1 Post by Gloria8733 » 15 Mar 2019, 10:01
Hi I have a 32G toshiba usb that is very important to me. every time when I try to access it I get this message "The request could not performed because of an I/O devices error" I searched on google to find the solution and the most appearing solution was to run this command "chkdsk /f m:".....m being the name of the drive.
I tried this but i get message "Cannot open volume for direct access"
diebestetest.de/
Sponsored links
Re: Usb not accessible because of I/O device error
#2 Post by cgrenier » 16 Mar 2019, 08:02
You should try to clone your USB key using ddrescue as described in https://www.cgsecurity.org/testdisk.pdf
Once it's done, remove the original device and run chkdsk on the clone.
Post Reply
Who is online
Users browsing this forum: Google Adsense [Bot] and 1 guest
