Help recovering erased SD card from Samsung phone
civvie
#1 Post by civvie »
My Samsung S8 phone and SD card were accidentally erased (a 'find my phone' mishap). :(
Many photos and videos were on the 64GB SD card.
I ran a scan with photorec and it saved a few 'recup_dir' folders to my computer.
In one of them is a 'f0044800.sqlite' file that is 64GB big.
I don't really know what I'm doing and if the scan was successful or not, or what to do with these files if so...
Can anyone give advice or point me towards a simple how-to SD card recovery for dummies like me?
I'm using a Mac, OS 10.12.6
Thank you!
Re: Help recovering erased SD card from Samsung phone
Run PhotoRec, in Options, enable the Expert mode, start the recovery, choose a blocksize of 512 bytes, use the defaults options otherwise.
Does it work better ?
civvie
#3 Post by civvie »
Thanks you! Where do I change the blocksize?
When you are running photorec, at least in the version 7.0 that I have, you are asked for a block size after selection a directory for recovery.
civvie
#5 Post by civvie »
OK - Thanks for the tips.
So, in expert mode, I've tried.
Partition: No partition [whole disk]
Filesystem: [Other] FAT/NTFS/...etc - I've also tried [ext2/ext3]
Try to unformat a FAT filesystem: No
(If I choose Yes here then it just starts and I don't get an option to select Blocksize)
-Then it starts but if I hit enter on 'Stop' then I get the menu to select blocksize
Blocksize: 512 (not 512k - correct?)
Everything I've tried so far just produces a few files:
report.xml
f0044800.sqlite (64GB)
f0030976.plist
f00330246.plist
That's it.
Am I screwed? :(
#6 Post by recuperation »
Hello civvie,
maybe your "accident" involved a "Format"-operation?
Please clone the SD card and try out the "Unformat option".
It's somehow strange that photorec did not find any jpeg-file.
Have you excluded some file formats?
civvie
#7 Post by civvie »
Hello.
Yes I assume it was formatted when phone erased its self - possibly a 'secure format' which might mean I'm toast (I didn't do this by the way - a friend did - long story...)
I have an image .dmg of the entire SD that another recovery program made. So that's a backup.
I haven't excluded any filetypes, default settings - apart from Expert Mode.
I think I tried Unformat already - When I do that I can't select the Blocksize though - is that right?
#8 Post by recuperation »
Hello cievvie,
civvie wrote: 16 Apr 2019, 13:13 Hello.
I don't know, unfortunately!
I would recommend retrying using the dmg-image to see if that gives a different result.
