Data Lost - Drive now has 6089429 TB / 5538303 TiB
lukas
#1 Post by lukas »
My Hard Drive recently crashed. It began with messages from windows that the drive is currently in use and as I was just making a backup I lost it completely.
So I opened diskmgmt.msc and it wasn't initialised - so I tried rewriting the MBR - no luck.
Then after reconnecting it and hoping it maybe would magically work again it showed this in diskmgmt.msc:
After seraching the Internet I then found this tool - testdisk.
It shows the same nonsense as windows:
(this also happend in linux btw) and trying to analyze it is taking forever.
Any thoughts?
Lukas
Re: Data Lost - Drive now has 6089429 TB / 5538303 TiB
Using the manufacturer tools or hdparm under Linux, you can try a DCO restore but if a wrong capacity is still reported, you should contact a data recovery company.
