First sorry my bad English
I'have problem with my one hard disk partition. It damaged when I was trying to recovery data from another disk with TestDisk. So I selected this damaged partition for TestDisk recovered files by mistake and now this partition is broken. I stopped file recovery about 20 seconds after I noticed that recovery saving target is wrong disk.
Testdisk show this information when I try use it to recovery damaged partition. Damaged partition is 7.
Disk /dev/sda - 320 GB / 298 GiB - CHS 38913 255 63
1 E extended LBA 1 0 62 38912 254 63 625121219
5 L Linux 1 1 1 1283 254 63 20611332
Bad relative sector.
X extended 1284 0 1 1669 254 63 6201090
6 L Linux Swap 1284 1 1 1669 254 63 6201027
X extended 1670 0 1 38912 254 63 598308795
7 L Linux 1670 1 1 38912 254 63 598308732
>[Quick Search] [ Backup ]
Try to locate partitionAfter Quick Search test disk list this:
Enter: to continue
EXT3 Large file Sparse superblock Recover, 10553 MB / 10064 MiBI tested Photorec but it split up lot of my mp3 files. Also it lose filesystem structure and filenames.
