Will TestDisk 7.1 Beta (download Windows 7 64bit) work on a Windows 7 64bir Ultimate guest on Windows 7 Pro 64bit host.
Maybe I should be using TestDisk 7.0 windows Download, rather than TestDisk 7.1 Beta with Windows64 download.
The Guest is a 42GB partition (38.9GiB).
The TestDisk.log shows:
The harddisk (42 GB / 40 GiB) seems too small! (< 85 GB / 79 GiB)
HPFS - NTFS 5221 137 36 10430 51 52 83677184
NTFS, blocksize=4096, 42 GB / 39 GiB
I am using VMWare Workstation 11.
This test was to exercise TestDisk before trying to recover Window 7 Master File Table (MFT) on a failing computer that keeps get Blue Screen BSOD)
The Windows 7 Guest has been running successfully since 2012 and is used for testingour newly developed applications.
VMWare Workstation 11 guest Windows 7
Re: VMWare Workstation 11 guest Windows 7
You can use the 7.1-WIP version.
An NTFS partition found using its backup boot sector should be listed on the next screen, TestDisk has been stopped too early.
Here is the full testdisk.log. Most relavent message is possibly:
"This partition ends after the disk limits."
David
Mon Jun 10 16:08:51 2019
TestDisk 7.1-WIP, Data Recovery Utility, May 2019
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=42949672960
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=42949672960
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=42842718208
Disk /dev/sda - 42 GB / 40 GiB - CHS 5221 255 63, sector size=512 - VMware, VMware Virtual S, FW:1.0
Disk /dev/sda - 42 GB / 40 GiB - VMware, VMware Virtual S
Analyse Disk /dev/sda - 42 GB / 40 GiB - CHS 5221 255 63
NTFS at 0/32/33
NTFS at 12/223/20
1 * HPFS - NTFS 0 32 33 12 223 19 204800 [System Reserved]
2 P HPFS - NTFS 12 223 20 5221 137 36 83677184
NTFS at 0/32/33
filesystem size 204800
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
filesystem size 83677184
mftmirr_lcn 2
file_pread(4,2,buffer,83886080(5221/170/6)) ReadFile Data error (cyclic redundancy check).
file_pread(4,1,buffer,83886080(5221/170/6)) ReadFile Data error (cyclic redundancy check).
file_pread(4,2,buffer,83886107(5221/170/33)) lseek err Invalid argument
file_pread(4,1,buffer,83886107(5221/170/33)) lseek err Invalid argument
file_pread(4,2,buffer,83886143(5221/171/6)) lseek err Invalid argument
file_pread(4,1,buffer,83886143(5221/171/6)) lseek err Invalid argument
file_pread(4,2,buffer,83886170(5221/171/33)) lseek err Invalid argument
file_pread(4,1,buffer,83886170(5221/171/33)) lseek err Invalid argument
file_pread(4,8,buffer,83886080(5221/170/6)) ReadFile Data error (cyclic redundancy check).
file_pread(4,1,buffer,83886081(5221/170/7)) lseek err Invalid argument
file_pread(4,14,buffer,83886082(5221/170/8)) lseek err Invalid argument
file_pread(4,3,buffer,83886096(5221/170/22)) lseek err Invalid argument
file_pread(4,3,buffer,83886143(5221/171/6)) lseek err Invalid argument
file_pread(4,8,buffer,83886159(5221/171/22)) lseek err Invalid argument
file_pread(4,11,buffer,83886206(5221/172/6)) lseek err Invalid argument
file_pread(4,2,buffer,83888128(5221/202/38)) lseek err Invalid argument
NTFS at 0/32/33
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/19
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
mftmirr_lcn 2
NTFS at 5221/137/36
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 42 GB / 39 GiB
NTFS at 5221/137/36
mftmirr_lcn 2
file_pread(4,2,buffer,90175493(5613/42/3)) lseek err Invalid argument
file_pread(4,1,buffer,90175493(5613/42/3)) lseek err Invalid argument
NTFS: Can't read MFT
This partition ends after the disk limits. (start=83884031, size=83677184, end=167561214, disk end=83886080)
file_pread(4,2,buffer,83886079(5221/170/5)) ReadFile Data error (cyclic redundancy check).
file_pread(4,7,buffer,83886081(5221/170/7)) lseek err Invalid argument
file_pread(4,8,buffer,83886088(5221/170/14)) lseek err Invalid argument
SIGINT detected! TestDisk has been killed.
David
NTFS at 0/32/33
NTFS at 12/223/20
NTFS at 0/32/33
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
mftmirr_lcn 2
NTFS at 0/32/33
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/19
mft_lcn 8533
mftmirr_lcn 2
NTFS at 12/223/20
mftmirr_lcn 2
NTFS at 5221/137/36
mftmirr_lcn 2
NTFS at 5221/137/36
mftmirr_lcn 2
