Can't repair filesystem with fsck, and TestDisk shows "no partition available"
revgrectifier
#1 Post by revgrectifier »
Hello everyone,
My 4TB external drive just stopped working a few days ago, and shows up on Mac's Disk Utility but I can't access it or repair it. I don't think the problem is mechanical as the HDD was quite new and wasn't used very much. I'm trying anything to repair it.
fsck_hfs -r -d returns:
journal_replay(/dev/disk3) returned 22
** /dev/rdisk3 (NO WRITE)
Using cacheBlockSize=32K cacheTotalBlock=65536 cacheSize=2097152K.
Executing fsck_hfs (version hfs-407.200.4).
Block 2 is not an MDB or Volume Header
Block 7814037165 is not an MDB or Volume Header
volumeType is 0
0000: 0000 0000 0000 0000 0000 0000 0000 0000 |................|
01b0: 0000 0000 0000 0000 0000 0000 0000 00fe |................|
01c0: ffff eefe ffff 0100 0000 feff ffff 0000 |................|
01d0: 0000 0000 0000 0000 0000 0000 0000 0000 |................|
01f0: 0000 0000 0000 0000 0000 0000 0000 55aa |..............U.|
unknown volume type
primary MDB is at block 0 0x00
alternate MDB is at block 0 0x00
primary VHB is at block 0 0x00
alternate VHB is at block 0 0x00
sector size = 512 0x200
VolumeObject flags = 0x01
total sectors for volume = 7814037167 0x1d1c0beaf
total sectors for embedded volume = 0 0x00
CheckHFS returned 6, fsmodified = 0
And when I try to repair HFS volume using the .pdf guide, and I go to the Advanced menu, TestDisk says that there is no partition available.
When I use TestDisk to Analyse I get three partitions, all "primary": DOS_FAT_32 (200MB), HFS (3725GB), and another HFS (128MB).
When I select the second partition, the 3725GB one which I think is the one containing all of my files, I'd like to "Write" it but I don't know if it could create more damage, in the case I'm doing something wrong.
How would you proceed?
Thank you very much!
Re: Can't repair filesystem with fsck, and TestDisk shows "no partition available"
revgrectifier wrote: 05 Jul 2019, 18:35 Hello everyone,
Another one bit the dust?
You had a broken driven two months ago:
viewtopic.php?f=6&t=7858&p=25284#p25284
The risk depends on the partition scheme used that you do not show. I don't see a risk for GPT. There is a risk for MBR-style schemes.
Your disk size rather suggests GPT.
If in doubt, make a backup.
Gather SMART information using smartmontools or similar software.
revgrectifier
#3 Post by revgrectifier »
recuperation wrote: 05 Jul 2019, 21:51
One year and two months ago, and bloody hell that was hard to fix...
When I analyse selecting EFI_GPT I get:
> Mac HFS 7813533180 15626247163 7812713984
Mac HFS 7814037124 7814299267 262144
Interestingly, when I select the biggest one of those two, and on the next step I mark as primary the biggest partition I find (still 3725GB), and then Quit, when I go to Advanced now I see two partitions while before I didn't see anything at all. Tempted to proceed with "Image Creation" on the largest Mac HFS one.
I downloaded smartmontools and ran it, it returned this:
General SMART Values:
Offline data collection status: (0x00) Offline data collection activity
was never started.
Auto Offline Data Collection: Disabled.
been run.
data collection: ( 0) seconds.
capabilities: (0x73) SMART execute Offline immediate.
command.
No Offline surface scan supported.
Self-test supported.
power-saving mode.
Short self-test routine
recommended polling time: ( 1) minutes.
Extended self-test routine
recommended polling time: ( 656) minutes.
Conveyance self-test routine
SCT capabilities: (0x30a5) SCT Status supported.
SCT Data Table supported.
SMART Attributes Data Structure revision number: 10
1 Raw_Read_Error_Rate 0x000f 100 029 006 Pre-fail Always - 2129111
3 Spin_Up_Time 0x0003 097 096 000 Pre-fail Always - 0
4 Start_Stop_Count 0x0032 094 094 020 Old_age Always - 6916
5 Reallocated_Sector_Ct 0x0033 100 100 010 Pre-fail Always - 0
7 Seek_Error_Rate 0x000f 081 060 045 Pre-fail Always - 121173082
9 Power_On_Hours 0x0032 092 092 000 Old_age Always - 7018 (56 153 0)
10 Spin_Retry_Count 0x0013 100 100 097 Pre-fail Always - 0
12 Power_Cycle_Count 0x0032 100 100 020 Old_age Always - 437
183 SATA_Downshift_Count 0x0032 100 100 000 Old_age Always - 0
184 End-to-End_Error 0x0032 100 100 099 Old_age Always - 0
187 Reported_Uncorrect 0x0032 001 001 000 Old_age Always - 38943
188 Command_Timeout 0x0032 100 007 000 Old_age Always - 141736477874
189 High_Fly_Writes 0x003a 100 100 000 Old_age Always - 0
190 Airflow_Temperature_Cel 0x0022 064 050 040 Old_age Always - 36 (Min/Max 26/36)
191 G-Sense_Error_Rate 0x0032 100 100 000 Old_age Always - 0
192 Power-Off_Retract_Count 0x0032 097 097 000 Old_age Always - 7014
193 Load_Cycle_Count 0x0032 069 069 000 Old_age Always - 63423
194 Temperature_Celsius 0x0022 036 050 000 Old_age Always - 36 (255 247 0 0 0)
195 Hardware_ECC_Recovered 0x001a 100 064 000 Old_age Always - 2129111
197 Current_Pending_Sector 0x0012 099 096 000 Old_age Always - 568
198 Offline_Uncorrectable 0x0010 099 096 000 Old_age Offline - 568
199 UDMA_CRC_Error_Count 0x003e 200 200 000 Old_age Always - 0
240 Head_Flying_Hours 0x0000 100 253 000 Old_age Offline - 1018 (179 139 0)
241 Total_LBAs_Written 0x0000 100 253 000 Old_age Offline - 39243584840
242 Total_LBAs_Read 0x0000 100 253 000 Old_age Offline - 100104163551
254 Free_Fall_Sensor 0x0032 100 100 000 Old_age Always - 0
SMART Error Log Version: 1
ATA Error Count: 38644 (device log contains only the most recent five errors)
CR = Command Register [HEX]
FR = Features Register [HEX]
ER = Error register [HEX]
ST = Status register [HEX]
Error 38644 occurred at disk power-on lifetime: 7005 hours (291 days + 21 hours)
ER ST SC SN CL CH DH
40 51 00 ff ff ff 0f Error: UNC at LBA = 0x0fffffff = 268435455
CR FR SC SN CL CH DH DC Powered_Up_Time Command/Feature_Name
25 d5 88 ff ff ff 4f 00 10:37:24.685 READ DMA EXT
b0 d5 01 c0 4f c2 00 00 10:37:24.388 SMART READ LOG
b0 d5 01 00 4f c2 00 00 10:37:24.388 SMART READ LOG
ef 03 46 e8 61 f5 00 00 10:37:24.388 SET FEATURES [Set transfer mode]
ef 03 0c e8 61 f5 00 00 10:37:24.388 SET FEATURES [Set transfer mode]
Error 38643 occurred at disk power-on lifetime: 7005 hours (291 days + 21 hours)
25 d5 88 ff ff ff 4f 00 10:37:02.446 READ DMA EXT
b0 d5 01 c0 4f c2 00 00 10:37:02.136 SMART READ LOG
b0 d5 01 00 4f c2 00 00 10:37:02.136 SMART READ LOG
ef 03 46 e8 61 f5 00 00 10:37:02.136 SET FEATURES [Set transfer mode]
ef 03 0c e8 61 f5 00 00 10:37:02.136 SET FEATURES [Set transfer mode]
Error 38642 occurred at disk power-on lifetime: 7005 hours (291 days + 21 hours)
25 d5 88 ff ff ff 4f 00 10:36:42.323 READ DMA EXT
b0 d5 01 c0 4f c2 00 00 10:36:42.020 SMART READ LOG
b0 d5 01 00 4f c2 00 00 10:36:42.020 SMART READ LOG
ef 03 46 e8 61 f5 00 00 10:36:42.020 SET FEATURES [Set transfer mode]
ef 03 0c e8 61 f5 00 00 10:36:42.020 SET FEATURES [Set transfer mode]
Error 38641 occurred at disk power-on lifetime: 7005 hours (291 days + 21 hours)
25 d5 88 ff ff ff 4f 00 10:36:23.915 READ DMA EXT
b0 d5 01 c0 4f c2 00 00 10:36:23.857 SMART READ LOG
b0 d5 01 00 4f c2 00 00 10:36:23.857 SMART READ LOG
ef 03 46 e8 61 f5 00 00 10:36:23.857 SET FEATURES [Set transfer mode]
ef 03 0c e8 61 f5 00 00 10:36:23.857 SET FEATURES [Set transfer mode]
Error 38640 occurred at disk power-on lifetime: 7005 hours (291 days + 21 hours)
25 d5 88 ff ff ff 4f 00 10:36:07.776 READ DMA EXT
b0 d5 01 c0 4f c2 00 00 10:36:07.725 SMART READ LOG
b0 d5 01 00 4f c2 00 00 10:36:07.725 SMART READ LOG
ef 03 46 e8 61 f5 00 00 10:36:07.725 SET FEATURES [Set transfer mode]
ef 03 0c e8 61 f5 00 00 10:36:07.724 SET FEATURES [Set transfer mode]
No self-tests have been logged. [To run self-tests, use: smartctl -t]
1 0 0 Not_testing
2 0 0 Not_testing
3 0 0 Not_testing
4 0 0 Not_testing
5 0 0 Not_testing
Time for duplication of your failing drive!
1 Raw_Read_Error_Rate 0x000f 100 029 006 Pre-fail Always - 2129111 !!!
7 Seek_Error_Rate 0x000f 081 060 045 Pre-fail Always - 121173082  !!!
Hardware_ECC_Recovered 0x001a 100 064 000 Old_age Always - 2129111  ???
197 Current_Pending_Sector 0x0012 099 096 000 Old_age Always - 568 !!!
198 Offline_Uncorrectable 0x0010 099 096 000 Old_age Offline - 568 !!!
Your drive is about to die.
Compare those lines to other drives you have.
After duplication recheck the SMART parameters again, maybe the figure for attribut 197 exploded...
Rerun testdisk after duplication on the duplicate.
revgrectifier
#5 Post by revgrectifier »
This sounds strange considering the drive wasn't used very much and was treated delicately.
How do I duplicate a drive I can't access, though? I've read the pdf for testdisk, photorec, etc, and I can't find instructions on how to duplicate a drive.
Do you think it's still worth it to try "Image Creation"?
#6 Post by recuperation »
revgrectifier wrote: 06 Jul 2019, 19:02 This sounds strange considering the drive wasn't used very much and was treated delicately.
A friend of mine has hard disk problems on a regular basis. I don't no why.
SMART parameters don't lie. Your justifications sound like you are beating your drives clandestinely. :)
What you consider "access" is a high level access on file system level.
Your "access" means viewing a drive name, files and folders.
There is an access on low level that you don't notice. SMART parameters and access on sector level is an example for that.
You can see the drive - that is the first indication of access.
You can pull SMART parameters - that is another indication of access.
Hopefully you will successfully duplicate the drive even though you don't have access on file system level.
I really don't buy that. :)
No, because of the high number of unreadable sectors you need a software that is designed to handle that.
Read the manual. You are allowed :) to use its directory which starts on pdf page 3.
Reading the whole manual is a good thing but in your case it is not needed.
revgrectifier
#7 Post by revgrectifier »
Didn't check the DDRescue part, only TestDisk! Okay so now I need an identical drive to write the copy to? Can I copy the disk to a file image and then write that disk image to a different disk?
#8 Post by recuperation »
revgrectifier wrote: 06 Jul 2019, 20:43 Didn't check the DDRescue part, only TestDisk! Okay so now I need an identical drive to write the copy to?
No, you only need another drive with equal or bigger size.
If you duplicate the content of your defective drive into a file, the destination drive has to be a little bit bigger than the source drive because the file system itself needs some space, too.
Can I do copy the disk to a file image and then write that disk image to a different disk?
Yes, you can.
revgrectifier
#9 Post by revgrectifier »
Currently writing the file image, it's taking a long time. Will update when it finishes, I'd say 2 days left tops.
revgrectifier
#10 Post by revgrectifier »
Finally it's finished writing that 4TB image.
Now, in order to write that .img file, I've looked around but Disk Utility doesn't mount it, when I double click it it says no mountable filesystem.
I've used
sudo dd if=path_of_your_image.img of=/dev/rdiskn bs=1m
obviously with my paths but it hasn't helped.
Also on this page it seems like the default would be to have a .dd image and rename it, while I just have an .img.
Tried to run TestDisk on the drive where I saved that 4TB .img file hoping there would be an option to write it somewhere but with no success...
