First, thanks for TestDisk
I use Ubuntu 12.04 for my work and sometime Windows 7 (games & music).
I've got an external hard drive of 1To with two partitions, one on ext4 format (where I've put three virtual machine for VirtualBox and where I dupplicate important files via DejaDup) and one on FAT32 format (where I put some files that could be opened on Ubuntu or on Windows). So I've cut the hard drive in two 500Go partitions.
When I've plugged my hard drive the other day, only the FAT32 was appearing… and I've discovered TestDisk
I've tried to check the disk but it couldn't seems to retrieve the ext4 partitions (three ext4 partitions were displayed, from where I couldn't see the content by using the P key). So I've tried the deep search…
… and here are the results (after 4 hours) :
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63
>D Linux 6483 58 40 7698 229 19 19529728
D Linux 6484 31 12 7699 201 54 19529728
D Linux 6484 193 46 7700 109 25 19529728
D Linux 6485 3 47 7700 174 26 19529728
D Linux 6486 106 21 7702 21 63 19529728
D Linux 6486 236 23 7702 152 2 19529728
D Linux 6489 23 63 7704 194 42 19529728
D Linux 6494 81 52 7709 252 31 19529728
D Linux 6495 21 55 7710 192 34 19529728
D Linux 6496 221 62 7712 137 41 19529728
D Linux 7938 241 48 9154 157 27 19529728
D Linux 7940 154 23 9156 70 2 19529728
D Linux 7941 126 58 9157 42 37 19529728
D Linux 28261 161 61 29477 77 40 19529728
D Linux 28264 112 9 29480 27 51 19529728
D Linux 28265 1 1 29480 254 63 19534977
D Linux 28268 67 24 29483 238 3 19529728
D Linux 28270 44 63 29485 215 42 19529728
D Linux 28271 115 5 29487 30 47 19529728
D Linux 28272 87 40 29488 3 19 19529728
D Linux 28274 97 48 29490 13 27 19529728
D Linux 28274 195 18 29490 110 60 19529728
* FAT32 LBA 63741 13 17 121601 57 56 929523712 [Windows]
Thanks a lot !
