Here is my misfortune. I mounted volumes in RAID5 on a cluster of three hard drives (3x1.5To, to avoid having problems with partitions larger than 2TB with windows).
I had a too short cable between the hard drive and the motherboard, so I moved it to another port nearest the motherboard. Following that, the PC doesn't boot anymore, I had a blue screen (BSOD).
So I put the default BIOS settings to boot. It worked, next I put back my settings, including the RAID configuration. After that, a volume is passed to rebuild and the other to failed ... Knowing that obviously, important datas are on the failed volume...
After searching with google, I found this solution:
http://forums.extremeoverclocking.com/s ... ostcount = 6
This is what I do, I deleted my volumes, I give them back identical settings, I run testdisk, it gives me this:
then
I never can list files, so I have not dared to do a write, what do you think about?
I have also plug back hard drives in the same order as before my change of ports, I launch testdisk, it give me same results as the images already shown.
Could anyone help me? : (
Thank you by advance.
PS: This topic already exist in the French section:
http://forum.cgsecurity.org/phpBB3/recu ... -t904.html
