TrueCrypt and bitlocker encryption error please help Topic is solved
rasanjadampriya
#1 Post by rasanjadampriya »
I have a 1TB HDD , one of my partitions worth 450GB was encrypted with Bitlocker Encryption ,
I was too lazy to Decrypt the volume because it takes hours to finish , so while the partition was unlocked
i encrypted the partition again with True Crypt , when the process was at 99% an error came up saying
"The media write is protected " ,
and
"An error prevented true crypt from resuming the process of encryption
of the partition , Please try fixing any previously reported problems and then try resuming the process again.
Note that the volume cannot be mounted until it has been fully encrypted "
Then i guessed that it had something to do with bitlocker , so i tried to decrypt it , but then it popped up an error
saying "Parameter error " . Now i cant decrypt it or mount it with trueCrypt :( I really need the Data on that partition no matter what it takes , I tired the CHKDSK r and f through CMD it didn't work either , it said RAW volume , but when i go through disk management it shows as NTFS (bitlcoker volume) . I tiried downloading the patch from microsoft web page , but when i install it says "This update is not applicable to your computer "
I tried booting with linux and ubunto , the partition was invisible maybe cause it was encrypted
I tried everything everyone told , :cry: please help me
thank you in advance
Re: TrueCrypt and bitlocker encryption error please help
Never encrypt an encrypted drive.
Don't run any tools or utilities against your disk like chkdsk.
Changing anything to your drive can make it unrecoverable
To diagnose your disk about TrueCrypt you should probably get in touch with simpson474.
http://sourceforge.net/projects/testcrypt/
rasanjadampriya
#3 Post by rasanjadampriya »
hmmm so shouldn't i run this utility on it as well ??? is it ok if i tried this ?? the data on the drive is really important to me , i didnt do anything to the volume , i let it be like that till i find a solution , the data is REALLY IMPORTANT :(
another friend of mine told me to try a software called "Nucleus NTFS recovery"
is it safe to try that ?? and THANK YOU for the time you took to reply :)
#4 Post by Fiona »
You shouldn't do anything unknowingly.
That's why I suggested to get in touch with simnpson474, is the Author of this tool.
His support should guide you through a diagnose, especially to get rid of any true crypt encryption.
This can make your data accessible again.
Bitlocker is another problem.
But the first way, what you can do would be my suggestion.
Please let me know.
rasanjadampriya
#5 Post by rasanjadampriya »
thank you for the advise , I didnt do anything , :) I went to that forum registered and messaged him/her ...hope that person will be kind enough to guide me through this :)
and thank you fiona for helping me out , I will let you know how it goes , keep in touch ;)
#6 Post by Fiona »
As long as your disk/partition is encrypted, as long no datarecovery software would be able to recognize any NTFS-partition, not to mention any data.
That's why it's a try to decrypt your drive and if you have no encryption anymore, you can diagnose your drive to get access to your data.
Simpson474
#7 Post by Simpson474 »
First of all sorry for the very late reply but the spam filter of Windows Live Mail has somehow classified your mail as junk. However I have also some good news: I used a virtual machine to encrypt a partition both with BitLocker and TrueCrypt and I was able with a modified TrueCrypt driver to access the volume afterwards. I will send you a PM with the link to the driver as it is quite untested (and produced some BSODs during development) so I do not want to have it available to everyone.
The first step you have to perform is installing TrueCrypt 7.0a - remove any newer version of TrueCrypt before installing TrueCrypt 7.0a. Afterwards you have to replace the "truecrypt.sys" file in "%WINDIR%\System32\drivers" using the modified version for your operating system (i386 or x64). After a re-start of Windows (you have to use the F8-Option "Disable Driver Signature Enforcement" on Windows 7 x64; press the Shift-key when clicking Restart on Windows 8) the modified driver should be used by TrueCrypt. Now unlock the BitLocker volume and try to mount the volume in TrueCrypt (the password has to be entered for 3 times to be accepted by TrueCrypt). Please do not mount any other TrueCrypt volume with the modified driver - I cannot guarantee that the volume will not be destroyed although the modified driver will only mount volumes read-only.
rasanjadampriya
#8 Post by rasanjadampriya »
thanks for the reply , Im gonna try it now , but mine it windows 7 32-bit , the f8 function doesnt seem to work on it , how do i disable it ??? I googled it , but everything is for 64-bit :o
rasanjadampriya
#9 Post by rasanjadampriya »
this is what happens when i put the passward 3 times
and this is what happens when i try to resume the process
rasanjadampriya
#10 Post by rasanjadampriya »
OMG OMG OMG OMG OMG ............ simson THANK YOU THANK YOU THANK YOU ........IT WORKED , YOU'RE MY HERO :D :D :D :D :D :D :D :D :D
I thank everyone who helped me specially simson and fiona , thank you all :D
