TrueCrypt and bitlocker encryption error please help Topic is solved
Re: TrueCrypt and bitlocker encryption error please help
Please make sure that the rescued data is really intact before re-formatting the partition - in my tests the results seemed to be OK but the driver has to perform some offset correction which could cause issues with files stored towards the end of the partition.
Im backing up all my data to another partition and then im going to format it completely , and encrypt it only using true crypt .
Thanks for your feedback to both of you.
I'll set this topic as solved.
