"Disk too small" problem
Laski
#1 Post by Laski »
Hi and sorry for my bad english! I have used testdisk before with great results but now I have a bigger problem. It's kind of similar to this one here: http://forum.cgsecurity.org/phpBB3/reco ... d-t15.html but with different parameters, reasons and partition types, and I don't know exactly how to "transpolate" the solution. Long story made short, I used testdisk to recover a partition -that's called wineprefix, that haves windows games for use them in linux- but by inexpertise selected all the others partitions as deleted. When I realised the problem, I ran testdisk again, but heres the situation:
http://img525.imageshack.us/img525/7958/captura01j.png
http://img198.imageshack.us/img198/7489/captura02v.png
As you can see, I can't recover my "Home" partition, wich is very important for me. Other partitions are OK, and I've already made a backup of them so I can play with what is left.
What I've tried: set the cilinders artificially to 124604 so testdisk could try to read the partitions, and then I could copy the contents to another disk and then exit without actually writing the bad geometry to disk. But...
Fri Jul 27 05:31:42 2012
TestDisk 6.11, Data Recovery Utility, April 2009
OS: Linux, kernel 3.0.0-22-generic (#36-Ubuntu SMP Tue Jun 12 17:13:04 UTC 2012)
Compiler: GCC 4.5 - Oct 17 2010 20:12:36
ext2fs lib: 1.41.14, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size       312581808 sectors
/dev/sda: user_max   312581808 sectors
/dev/sda: native_max 312581808 sectors
/dev/sda: dco        312581808 sectors
/dev/sdb: size       1953525168 sectors
/dev/sdb: user_max   1953525168 sectors
/dev/sdb: dco        1953525168 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - ATA Maxtor 6V160E0
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ATA ST31000333AS
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - Generic External
Disk /dev/sdd - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WD 1600BEV External
Disk /dev/sr0 - 190 MB / 181 MiB - CHS 92867 1 1 (RO), sector size=2048 - HL-DT-ST DVDRAM GH20NS15
Disk /dev/sdb - 1000 GB / 931 GiB - ATA ST31000333AS
New geometry
Disk /dev/sdb - 1024 GB / 954 GiB - CHS 124605 255 63 sector_size=512
Analyse Disk /dev/sdb - 1024 GB / 954 GiB - CHS 124605 255 63
NTFS at 0/1/1
NTFS at 19582/1/1
get_geometry_from_list_part_aux head=255 nbr=3
 1 P HPFS - NTFS              0   1  1 19581 254 63  314584767
 2 P HPFS - NTFS          19582   1  1 95492 129 51 1219502265 [shared]
 3 P Linux                96145  88  8 98103 120  1   31457280
Backup partition structure
partition_save
search_vista_part: 1
NTFS at 0/1/1
filesystem size           314584767
sectors_per_cluster       8
mftmirr_lcn               2
clusters_per_mft_record   -10
     NTFS, 161 GB / 150 GiB
NTFS at 19582/1/1
filesystem size           1219502265
mft_lcn                   88146816
mftmirr_lcn               4411315
     NTFS, 624 GB / 581 GiB
     Linux Swap           95492 162 31 96145  87 54   10485744
     SWAP2 version 1, 5368 MB / 5119 MiB
recover_EXT2: s_block_group_nr=0/120, s_mnt_count=9/37, s_blocks_per_group=32768, s_inodes_per_group=8208
recover_EXT2: s_blocks_count 3932160
recover_EXT2: part_size 31457280
     EXT4 Large file Sparse superblock, 16 GB / 15 GiB
   * HPFS - NTFS              0   1  1 19581 254 63  314584767
   P Linux Swap           95492 162 31 96145  87 54   10485744
   L Linux                96145  88  8 98103 120  1   31457280
 1 * HPFS - NTFS              0   1  1 19581 254 63  314584767
 3 P Linux Swap           95492 162 31 96145  87 54   10485744
 4 E extended LBA         96145  88  1 124604 254 63  457204356
 5 L Linux                96145  88  8 98103 120  1   31457280
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 0/1/1
NTFS at 19582/1/1
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
recover_EXT2: s_block_group_nr=0/1440, s_mnt_count=10/31, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 47185920
recover_EXT2: part_size 377487360
     Linux                101060  74  7 124557 201 60  377487360 [Home]
     EXT4 Large file Sparse superblock Recover, 193 GB / 180 GiB
   L Linux                101060  74  7 124557 201 60  377487360 [Home]
dir_partition inode=2
ext2fs_dir_iterate failed with error 2133571387.
 6 L Linux                101060  74  7 124557 201 60  377487360 [Home]
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 13055/15/16
filesystem size           209729465
mft_lcn                   4
mftmirr_lcn               19661547
     HPFS - NTFS              0   1  9 13055  15 16  209729465
     NTFS found using backup sector!, 107 GB / 100 GiB
recover_EXT2: s_block_group_nr=0/399, s_mnt_count=17/35, s_blocks_per_group=32768, s_inodes_per_group=8192
recover_EXT2: s_blocks_count 13106432
recover_EXT2: part_size 104851456
     Linux                16207  79  1 22734   2 52  104851456 [wineprefix]
     EXT4 Large file Sparse superblock Recover, 53 GB / 49 GiB
     Linux                16210   2  1 22736 180 52  104851456 [wineprefix]
NTFS at 19581/254/63
mftmirr_lcn               2
     NTFS found using backup sector!, 161 GB / 150 GiB
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 94839/171/52
filesystem size           1209014457
mft_lcn                   88146816
mftmirr_lcn               4411315
     HPFS - NTFS          19582   1 11 94839 171 52 1209014457
     NTFS found using backup sector!, 619 GB / 576 GiB
NTFS at 95492/129/61
mft_lcn                   88146816
mftmirr_lcn               4411315
     HPFS - NTFS          19582   1 11 95492 129 61 1219502265
     NTFS found using backup sector!, 624 GB / 581 GiB
NTFS at 96145/55/38
filesystem size           20971513
mft_lcn                   4
mftmirr_lcn               655648
     HPFS - NTFS          94839 204 29 96145  55 38   20971513
     NTFS found using backup sector!, 10737 MB / 10239 MiB
NTFS at 96145/88/7
filesystem size           20973561
mft_lcn                   4
mftmirr_lcn               655648
     HPFS - NTFS          94839 204 29 96145  88  7   20973561
     NTFS found using backup sector!, 10 GB / 10 GiB
recover_EXT2: s_block_group_nr=0/120, s_mnt_count=34/37, s_blocks_per_group=32768, s_inodes_per_group=8208
     Linux                96951 203 21 98909 235 14   31457280
     EXT4 Large file Sparse superblock Recover, 16 GB / 15 GiB
     Linux                101061  46 42 124558 174 32  377487360 [Home]
     Linux                101069 184 44 124567  57 34  377487360 [Home]
     Linux                101080 110 23 124577 238 13  377487360 [Home]
     Linux                101104   4 21 124601 132 11  377487360 [Home]
     Linux                101105 139 27 124603  12 17  377487360 [Home]
     Linux Swap           110949 247 19 111015  61  6    1048560
     SWAP2 version 1, 536 MB / 511 MiB
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
get_geometry_from_list_part_aux head=8 nbr=3
get_geometry_from_list_part_aux head=16 nbr=3
ext2fs_dir_iterate failed with error 1.
ext2fs_dir_iterate failed with error 2133571402.
Disk /dev/sda - 160 GB / 149 GiB - ATA Maxtor 6V160E0
Analyse Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63
NTFS at 0/1/1
heads/cylinder 4 (NTFS) != 255 (HD)
sect/track 17 (NTFS) != 63 (HD)
NTFS at 13056/1/1
Info: size boot_sector 102835385, partition 102848067
get_geometry_from_list_part_aux head=16 nbr=4
get_geometry_from_list_part_aux head=32 nbr=4
get_geometry_from_list_part_aux head=64 nbr=4
get_geometry_from_list_part_aux head=128 nbr=4
get_geometry_from_list_part_aux head=240 nbr=4
Warning: Incorrect number of heads/cylinder 4 (NTFS) != 255 (HD)
Warning: Incorrect number of sectors per track 17 (NTFS) != 63 (HD)
 1 * HPFS - NTFS              0   1  1 13055 254 63  209744577 [Ex XP]
 2 E extended LBA         13056   0  1 19457 254 63  102848130
 5 L HPFS - NTFS          13056   1  1 19457 254 63  102848067
Ask the user for vista mode
search_vista_part: 0
NTFS at 0/1/1
filesystem size           209744577
mftmirr_lcn               2
     NTFS, 107 GB / 100 GiB
NTFS at 13056/1/1
filesystem size           102835385
mftmirr_lcn               6425996
     HPFS - NTFS          13056   1  1 19457  53 44  102835385
     NTFS, 52 GB / 49 GiB
get_geometry_from_list_part_aux head=32 nbr=3
get_geometry_from_list_part_aux head=64 nbr=3
get_geometry_from_list_part_aux head=128 nbr=3
get_geometry_from_list_part_aux head=240 nbr=3
 1 P HPFS - NTFS              0   1  1 13055 254 63  209744577 [Ex XP]
 2 * HPFS - NTFS          13056   1  1 19457 254 63  102848067
write!
New options :
 Dump : No
 Cylinder boundary : Yes
 Expert mode : No
It recognized the partitions but could read none. I'm very confused now, and I would aprecciate every hint that you can give to me. I know the files are there, I won't give up until I have recovered them. With your help, I hope we'll can.
Thank you so much!
Re: "Disk too small" problem
Looks like your partition is somehow resized and ends after disk limit.
You can have a try to increase your size of cylinders to get access to your home partition.
But this is only intended for diagnose purposes and in case to copy your data from;
Example;
http://forum.cgsecurity.org/phpBB3/post ... imit#p3435
Please read all carefully.
Your value to get access to your partition would be 124604.
Please check each listed home partition and try to list your data.
Laski
#3 Post by Laski »
Fiona:
First, thank you for answering. Second, unfortunatly I've already tried that (and I took the idea from your posts in the thread you just linked to), but the 'new' partitions that testdisk find can't be read and thus there's no content to copy. I copy again the testdisk log (also in the first post on this thread) but with some garbage off.
Laski wrote: What I've tried: set the cilinders artificially to 124604 so testdisk could try to read the partitions, and then I could copy the contents to another disk and then exit without actually writing the bad geometry to disk. But...
New geometry
NTFS at 0/1/1
NTFS at 19582/1/1
partition_save
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 13055/15/16
mft_lcn                   4
mftmirr_lcn               2
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
mft_lcn                   88146816
mftmirr_lcn               4411315
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 96145/55/38
mft_lcn                   4
mftmirr_lcn               655648
NTFS at 96145/88/7
mft_lcn                   4
mftmirr_lcn               655648
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 0/1/1
NTFS at 13056/1/1
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 13056/1/1
mftmirr_lcn               6425996
write!
New options :
 Dump : No
 Expert mode : No
Laski
#4 Post by Laski »
I don't know if this is legal here but my problem isn't solved and my thread went very far away from first page so...
UP!
PD: If it's illegal and I must repost the thread please notify me.
Laski
#5 Post by Laski »
Hi!
#6 Post by cgrenier »
Can you try again using TestDisk 6.14-WIP ?
wget -N http://www.cgsecurity.org/testdisk-6.14-WIP.linux26.tar.bz2
tar xjf testdisk-6.14-WIP.linux26.tar.bz2
cd testdisk-6.14-WIP
sudo ./testdisk_static
Laski
#7 Post by Laski »
Of course.
Mon Sep 10 00:01:13 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
OS: Linux, kernel 3.0.0-22-generic (#36-Ubuntu SMP Tue Jun 12 17:13:04 UTC 2012) i686
Compiler: GCC 4.4
Compilation date: 2012-08-30T21:56:20
ext2fs lib: 1.41.12, ntfs lib: libntfs-3g, reiserfs lib: 0.3.1-rc8, ewf lib: 20100226
Disk /dev/sda - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - Maxtor 6V160E0, S/N:V40V0BKG, FW:VA111900
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - ST31000333AS, S/N:9TE20CF3, FW:CC1H
Disk /dev/sdc - 160 GB / 149 GiB - CHS 19457 255 63, sector size=512 - WD 1600BEV External, FW:1.75
Disk /dev/sr0 - 190 MB / 181 MiB - 92867 sectors (RO), sector size=2048 - HL-DT-ST DVDRAM GH20NS15, S/N:K5685TA2619, FW:IL00
Disk /dev/sdb - 1000 GB / 931 GiB - ST31000333AS
NTFS at 0/1/1
NTFS at 19582/1/1
NTFS at 0/1/1
mftmirr_lcn               2
     NTFS, blocksize=4096, 161 GB / 150 GiB
Error: size boot_sector 1219502265 > partition 1209014467
     HPFS - NTFS          19582   1  1 94839 171 52 1209014467
     SWAP2 version 1, pagesize=4096, 5368 MB / 5119 MiB
recover_EXT2: s_block_group_nr=0/120, s_mnt_count=20/37, s_blocks_per_group=32768, s_inodes_per_group=8208
     ext4 blocksize=4096 Large file Sparse superblock, 16 GB / 15 GiB
     ext4 blocksize=4096 Large file Sparse superblock Recover, 193 GB / 180 GiB
This partition ends after the disk limits. (start=1623533568, size=377487360, end=2001020927, disk end=1953525168)
This partition ends after the disk limits. (start=1623547904, size=377487360, end=2001035263, disk end=1953525168)
This partition ends after the disk limits. (start=1623685120, size=377487360, end=2001172479, disk end=1953525168)
This partition ends after the disk limits. (start=1623857152, size=377487360, end=2001344511, disk end=1953525168)
This partition ends after the disk limits. (start=1624236032, size=377487360, end=2001723391, disk end=1953525168)
This partition ends after the disk limits. (start=1624260608, size=377487360, end=2001747967, disk end=1953525168)
     SWAP2 version 1, pagesize=4096, 536 MB / 511 MiB
The harddisk (1000 GB / 931 GiB) seems too small! (< 1024 GB / 954 GiB)
     HPFS - NTFS          19582   1  1 94839 254 63 1209019707
     Linux Swap           95492 162 31 96145  88  7   10485760
     SWAP2 version 1, pagesize=4096, 5368 MB / 5120 MiB
     Linux Swap           110949 247 19 111015  61 22    1048576
     SWAP2 version 1, pagesize=4096, 536 MB / 512 MiB
New geometry
Disk /dev/sdb - 1024 GB / 954 GiB - CHS 124604 255 63 sector_size=512
Analyse Disk /dev/sdb - 1024 GB / 954 GiB - CHS 124604 255 63
NTFS at 0/1/1
NTFS at 19582/1/1
NTFS at 0/1/1
mftmirr_lcn               2
       2 drwxr-xr-x     0      0      4096 17-Nov-2011 23:04 .
       2 drwxr-xr-x     0      0      4096 17-Nov-2011 23:04 ..
      11 drwx------     0      0     16384 22-Sep-2011 02:30 lost+found
  131329 drwxr-xr-x     0      0      4096 26-Sep-2011 03:40 var
  525313 drwxr-xr-x     0      0      4096 24-Feb-2012 22:36 home
  787969 drwxr-xr-x     0      0     12288 24-Feb-2012 22:38 etc
  262657 drwxr-xr-x     0      0      4096 18-Nov-2011 00:12 media
  656641 drwxr-xr-x     0      0      4096  2-Nov-2011 23:25 bin
  393985 drwxr-xr-x     0      0      4096 17-Nov-2011 01:13 boot
  787971 drwxr-xr-x     0      0      4096 22-Feb-2012 18:34 dev
  262658 drwxr-xr-x     0      0      4096 28-Sep-2011 04:04 lib
      12 lrwxrwxrwx     0      0         4 22-Sep-2011 02:30 lib64
  393986 drwxr-xr-x     0      0      4096 21-Apr-2011 13:51 mnt
  525314 drwxr-xr-x     0      0      4096  5-Oct-2011 01:17 opt
  656642 drwxr-xr-x     0      0      4096 21-Apr-2011 13:51 proc
  525315 drwx------     0      0      4096 18-Nov-2011 02:08 root
  787972 drwxr-xr-x     0      0     12288 16-Nov-2011 16:43 sbin
  262659 drwxr-xr-x     0      0      4096 21-Mar-2011 05:35 selinux
      13 drwxr-xr-x     0      0      4096 25-Apr-2011 19:51 srv
  393987 drwxr-xr-x     0      0      4096 28-Mar-2011 17:21 sys
  656643 drwxrwxrwt     0      0     20480 24-Feb-2012 22:38 tmp
  262660 drwxr-xr-x     0      0      4096 22-Sep-2011 03:03 usr
   19128 lrwxrwxrwx     0      0        33 17-Nov-2011 01:13 initrd.img
      14 lrwxrwxrwx     0      0        30 17-Nov-2011 01:13 vmlinuz
X   1213 lrwxrwxrwx     0      0        30 28-Sep-2011 02:49 vmlinuz.15383
  413265 drwxr-xr-x     0      0     12288 26-Sep-2011 05:16 lib32
    1212 lrwxrwxrwx     0      0        33 28-Sep-2011 02:49 initrd.img.old
    1213 lrwxrwxrwx     0      0        30 28-Sep-2011 02:49 vmlinuz.old
X   2681 drwx------  1000   1000      4096 24-Feb-2012 22:37 device.map.rescatux
ntfs_ucstoutf8: iconv_open failed
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 13055/15/16
mft_lcn                   4
     NTFS found using backup sector, blocksize=4096, 107 GB / 100 GiB
     ext4 blocksize=4096 Large file Sparse superblock Recover, 53 GB / 49 GiB
     HPFS - NTFS          19581  96 36 90923  75 32 1146107904
mftmirr_lcn               2
     NTFS found using backup sector, blocksize=4096, 161 GB / 150 GiB
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
     NTFS, blocksize=4096, 624 GB / 581 GiB
mft_lcn                   88146816
mftmirr_lcn               4411315
     NTFS found using backup sector, blocksize=4096, 619 GB / 576 GiB
mft_lcn                   88146816
mftmirr_lcn               4411315
     NTFS found using backup sector, blocksize=4096, 624 GB / 581 GiB
NTFS at 96145/55/38
mft_lcn                   4
mftmirr_lcn               655648
     NTFS found using backup sector, blocksize=4096, 10737 MB / 10239 MiB
NTFS at 96145/88/7
mft_lcn                   4
mftmirr_lcn               655648
     NTFS found using backup sector, blocksize=4096, 10 GB / 10 GiB
     ext4 blocksize=4096 Large file Sparse superblock Recover, 16 GB / 15 GiB
NTFS at 0/1/1
mftmirr_lcn               2
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
NTFS at 19582/1/1
mft_lcn                   88146816
mftmirr_lcn               4411315
     HPFS - NTFS          19582   1  1 95492 254 63 1219510152 [shared]
Thank you very much for answering!
#8 Post by cgrenier »
After Deeper Search, several Home partitions are listed. For each partition, use 'p' to list its content.
This way you should be able to find which one is correct. Use the arrow keys to switch this partition from D(eleted) to P(rimary). Do the same for the other partitions you want to keep/recover. On next screen, if all your partitions are listed, choose Write, confirm, Quit and restart your computer.
Laski
#9 Post by Laski »
cgrenier wrote:After Deeper Search, several Home partitions are listed. For each partition, use 'p' to list its content.
Hey, I'm not a total n00b :lol:. That was, as you say, the first thing I tried. Were that worked, I woudn't have posted the log and in replace will be a very big "Thank you" :). But the situation was the same as with the 6.11 version. As you can see in this part of the log
they all showed an error when I tried to list files. I think I need to do something with the start and end block data, but I don't know exactly what and I don't wanna mess things up playing around with commands that nobody told me how to use. I already did enough damage :?.
Thank you again!
raichu21
#10 Post by raichu21 »
hi I'm using WD 3TB HDD
first, my file was lost.
so, I found this testdisk program and I try to fix it.
suddenly, my file capacity was bigger than ever.
how can I find my files and original capacity?
seems to too big..
I want to find my files and orginal capacity. too big now
