I am trying to recover a partition on my Seagate 3TB.
There is one partition spanning the entire disk.
It was formatted in windows, with EFI using default options.
Selecting The drive, choosing 'EFI' and then Analyzing, testdisk discovers a partition table of type MS Data. There is an error message showing 'number of bytes per sector mismatches 1024 (NTFS) != 512 (HD)'.
The files do list without a problem.
Writing the partition table to the disc and rebooting, shows the filesystem as RAW in windows and inaccessible. testdisk can still list the files.
test version 6.14 WIP, windows, 32 bit.
After this there are a whole lot of errors(3 shown here, about 200 of these):
Mon Jul 30 20:34:20 2012
TestDisk 6.14-WIP, Data Recovery Utility, July 2012
OS: Windows 7 (7600)
Compilation date: 2012-07-28T12:34:33
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=3000592982016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=120034123776
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=500106780160
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=119926685696
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\D:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000457232384
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=500103643136
Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - ST3000DM001-9YN166, S/N:2020202020202020202020203153304654323441, FW:CC4C
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - WDC WD30EZRX-00MMMB0, S/N:2020202057202d4443575741315a363939333033, FW:80.00A80
Disk /dev/sdc - 120 GB / 111 GiB - CHS 14593 255 63, sector size=512 - INTEL SSDSC2CT120A3, S/N:5643504d3232343136305747323142304e472020, FW:300i
Disk /dev/sdd - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST3500320NS, S/N:2020202020202020202020205139324d36394841, FW:SN04
Disk /dev/sda - 3000 GB / 2794 GiB - ST3000DM001-9YN166
Partition table type: EFI GPT
Analyse Disk /dev/sda - 3000 GB / 2794 GiB - CHS 364801 255 63
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=5860533167 (expected 5860533167)
hdr_lba_start=34
hdr_lba_end=5860533134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
Warning: number of bytes per sector mismatches 1024 (NTFS) != 512 (HD)
1 P MS Data 264192 5860532223 5860268032 [SEAGATE_3TB]
NTFS at 16/113/34
filesystem size 2930134016
sectors_per_cluster 4
mftmirr_lcn 2
file_pread(4,2,buffer,1565566976(364801/98/34))
Thanks for any help in advancelseek err Invalid argument
file_pread(4,1,buffer,1565567341(364801/104/21)) lseek err Invalid argument
file_pread(4,1,buffer,1565567342(364801/104/22))
