Where to store recovered data?
Tomjika
Re: Where to store recovered data?
#11 Post by Tomjika »
I'm trying to recover data on my second internal hardrive and I have the same problem where I can't select the destination other than on C:/. I don't have access to the other drives, especially the USB one that will be the recepient of saved data. I have hit the left arrow numerous times but no effect, just stock on C:/.
Thank you for your help.
#12 Post by cgrenier »
Tomjika, TestDisk can let you write on partitions where your running OS can access.
Ie. you are booting from DOS, you will not be able to access NTFS or exFAT.
Tomjika
#13 Post by Tomjika »
Thank you for your answer. The thing is that I'm not booting on DOS, I'm running photorec_win.exe from Windows 8.
hobbert
#14 Post by hobbert »
Finally figured out a fix..
copy the photorec folder to destination drive
open dos box
navigate to that drive
run photorec
boom - your able to save to the destination drive you want
maybe it will work without using dos box but that is how i did it
