Hi all,
Sadly my partition table is corrupt and I have a couple of truecrypt volumes that I need to try to recover. I'm running linux, in case this simplifies things.
cfdisk shows:
FATAL ERROR: Bad logical partition 8: enlarged logical partitions overlap
Press any key to exit cfdisk
fdisk -l shows:
Disk /dev/sdb: 320.1 GB, 320072932352 bytes
255 heads, 63 sectors/track, 38913 cylinders, total 625142446 sectors
Disk identifier: 0xf0859161
Device Boot Start End Blocks Id System
/dev/sdb1 2048 19853311 9925632 27 Hidden NTFS WinRE
/dev/sdb2 * 19853312 20058111 102400 7 HPFS/NTFS/exFAT
/dev/sdb3 20058112 184178687 82060288 7 HPFS/NTFS/exFAT
/dev/sdb4 184178688 625141759 220481536 f W95 Ext'd (LBA)
/dev/sdb5 378923008 574946647 98011820 7 HPFS/NTFS/exFAT
/dev/sdb6 574947328 622972927 24012800 83 Linux
/dev/sdb7 622974976 625141759 1083392 82 Linux swap / Solaris
/dev/sdb8 184180736 378908671 97363968 83 Linux
I think that it's sdb3 and sdb5 that I really need to recover. Anything else would be a bonus.
testdisk initially shows:
Disk /dev/sdb - 320 GB / 298 GiB - CHS 38913 255 63
1 P Windows RE(store) 0 32 33 1235 206 59 19851264
2 * HPFS - NTFS 1235 206 60 1248 142 46 204800 [System Reserved]
Invalid NTFS or EXFAT boot
3 P HPFS - NTFS 1248 142 47 11464 151 15 164120576
4 E extended LBA 11464 151 16 38913 70 5 440963072
5 L HPFS - NTFS 23586 220 59 35788 197 17 196023640
X extended 35788 197 18 38778 69 11 48026280
6 L Linux 35788 208 5 38778 69 11 48025600
X extended 38778 69 12 38913 70 5 2168832
7 L Linux Swap 38778 101 44 38913 70 5 2166784
X extended 11464 151 17 23585 248 23 194729983
8 L Linux 11464 183 48 23585 248 23 194727936
But then says is unable to recover.
Can anyone give me any pointers as to backing up what I have and any potential recovery actions?
Many thanks,
Mark
Partition table corruption (truecrypt volumes)
