So, the case is as follows:
After much work I finally found space in my hdd to create a 250GB partition the PS4 asks as a minimum. So by then I had a NTFS partition with all my files at around 640gb and a blank exFAT partition. Then I plugged it in. As the PS4 only found that exFAT partition and asked me "would you like to format it?" I thought "well... If it only found this, it can't format the whole storage, right?". Wrong. I know, I could've looked somewhere else before doing that, paid more attention to whatever, but I didn't. It formatted my whole external HD, wiping around 620 gb of data. As it was a quick process, I thought to myself "it just made a quick format, it can be reversed". I downloaded some recovery programs that showed me all my files (but I had to pay to have them back), until I found testdisk and photorec.
Yesterday I recovered probably most of my pictures, which were the most sensible files for me, so I'm at least partially relieved now (it recovered 4600 pictures of around 5000 that were inside, previously). I'm now running photorec again for the rest of the files, and it looks like it's going to be successful (I ran it over night, but it was literally finding around 1 million+ .ts files, breaking my 12GB files into 150kb-15mb or so ,so I canceled everything and restarted without the .ts files), but what I really want is my HD back with my folders and files in order and correctly named and all that.
So, when I run testdisk it shows me my HDD one whole 1TB storage (so no 250GB exFAT partition anymore) and as "P unknown", as it has no specified partition anymore, not even the previous NTFS. It also says "Partition sector doesn't have the endmark 0xAA55". The quick search, which I'm doing right now, is probably gonna take 10 more hours. It searches around 150 sectors per second (currenrly is at around 16000 out of 121599). Nothing was found until now, no errors, but nothing else. Don't know if I should be happy or not.
Also in advanced it says the status of the NTFS boot sector is bad and the backup boot sector is bad. Boot sectors are not identical. I tried to do the advanced > RebuildBS as I read in some posts, but I've read people saying their files vanished after that, so I canceled and started the photorec backup. I'd rather finish it before trying that RebuildBS.
Intriguingly, Google searches take me no where near a solution, since, apparently, no one ever responds to people who have done the same mistake as me, apart from this one post in an Ubuntu forum in French. I can read a bit of French, but just to be sure I also used Google translator (which has done a very decent job in this case). Unfortunately, when we get to post #23 things start to diverge: the quick search of the user Caryn apparently only took them 1 minute (from previous command from the helper/poster to their answer), while my quick search is taking a long time... Anyway, that is all the info I can give you now, since I can't even send a copy of the log yet.
https://translate.googleusercontent.com ... CFyoCoTaQA
By the way, I'm using windows (but I also have a mac system. I just don't have/use linux).
I hope any of you can help me.
External hdd formatted by PS4. No end 0XAA55
tabaquinho
Re: External hdd formatted by PS4. No end 0XAA55
As the filesystem has been reformated, TestDisk will not help.
There is a chapter in https://www.cgsecurity.org/testdisk.pdf about sorting the files recovered by PhotoRec.
But unfortunately it will not give you back the original filenames.
tabaquinho
BTW, I will update the original post with the French Ubuntu website I mentioned, but forgot to add haha
EDIT: here you go the log
Just before that: I remembered I actually had a bootable partition on my external hdd for windows installation, that is the FAT32 partition that was found along my bigger NTFS partition. When I clicked to open the NTFS partition I got a Can't open filesystem. Filesystem seems damaged. message. I dont care for the smaller partition, this is the one that matters. Do you think I can recover it?
when I click in Advance while in Intel it only gives me No partition available.
Thu Sep 5 20:03:00 2019
OS: Windows 8 (9200)
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sda)=500277790720
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdc)=1000194400256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive0)=500277790720
filewin32_getfilesize(\\.\PhysicalDrive1) GetFileSize err Função incorreta.
filewin32_setfilepointer(\\.\PhysicalDrive1) SetFilePointer err Função incorreta.
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive2)=1000194400256
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=180067762176
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=0
Disk /dev/sda - 500 GB / 465 GiB - CHS 60821 255 63, sector size=512 - APPLE SSD SM0512F, S/N:S1K5NYBF564185, FW:UXM2JA1Q
Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121600 255 63, sector size=512 - Samsung M3 Portable, S/N:00000000011E496F, FW:3
Disk /dev/sdc - 1000 GB / 931 GiB - Samsung M3 Portable
Analyse Disk /dev/sdc - 1000 GB / 931 GiB - CHS 121600 255 63
BAD_RS LBA=2952098144 2228443
file_pread(5,3,buffer,2952098144(183759/155/45)) lseek err Invalid argument
file_pread(5,1,buffer,2952098144(183759/155/45)) lseek err Invalid argument
FAT32 LBA 183759 155 45 214177 213 55 488668835
This partition ends after the disk limits. (start=2952098144, size=488668835, end=3440766978, disk end=1953504688)
HPFS - NTFS 114675 0 1 121599 254 63 111250125
exFAT, blocksize=131072, 56 GB / 53 GiB
file_pread(5,2,buffer,1953506048(121600/32/33)) lseek err Invalid argument
file_pread(5,1,buffer,1953506048(121600/32/33)) lseek err Invalid argument
file_pread(5,2,buffer,1953506111(121600/33/33)) lseek err Invalid argument
file_pread(5,1,buffer,1953506111(121600/33/33)) lseek err Invalid argument
file_pread(5,8,buffer,1953504691(121600/10/62)) lseek err Invalid argument
file_pread(5,1,buffer,1953504691(121600/10/62)) lseek err Invalid argument
file_pread(5,8,buffer,1953504819(121600/13/1)) lseek err Invalid argument
file_pread(5,8,buffer,1953504947(121600/15/3)) lseek err Invalid argument
file_pread(5,8,buffer,1953505075(121600/17/5)) lseek err Invalid argument
file_pread(5,8,buffer,1953505203(121600/19/7)) lseek err Invalid argument
file_pread(5,2,buffer,1953505280(121600/20/21)) lseek err Invalid argument
file_pread(5,14,buffer,1953505282(121600/20/23)) lseek err Invalid argument
file_pread(5,3,buffer,1953505296(121600/20/37)) lseek err Invalid argument
file_pread(5,3,buffer,1953505343(121600/21/21)) lseek err Invalid argument
file_pread(5,8,buffer,1953505359(121600/21/37)) lseek err Invalid argument
file_pread(5,11,buffer,1953505406(121600/22/21)) lseek err Invalid argument
file_pread(5,2,buffer,1953507328(121600/52/53)) lseek err Invalid argument
The harddisk (1000 GB / 931 GiB) seems too small! (< 1761 GB / 1640 GiB)
* HPFS - NTFS 114675 0 1 121599 254 63 111250125
dir_partition inode=0
5 drwxr-xr-x 0 0 131072 8-Nov-2018 23:42 System Volume Information
X 8 drwxr-xr-x 0 0 131072 8-Nov-2018 05:43 .Spotlight-V100
X 16 drwxr-xr-x 0 0 131072 11-Aug-2019 00:40 .fseventsd
X 29 drwxr-xr-x 0 0 131072 28-Jun-2019 16:36 LOST.DIR
X 30 drwxr-xr-x 0 0 131072 28-Jun-2019 16:36 Android
X 33885 drwxr-xr-x 0 0 131072 8-Nov-2018 06:11 .Trashes
X 41 drwxr-xr-x 0 0 131072 13-Nov-2018 20:46 cpy-rottr20yc
276928 drwxr-xr-x 0 0 131072 14-Nov-2018 04:13 $RECYCLE.BIN
dir_partition inode=5
Directory /System Volume Information
6 -rwxr-xr-x 0 0 12 8-Nov-2018 23:42 WPSettings.dat
7 -rwxr-xr-x 0 0 76 8-Nov-2018 23:42 IndexerVolumeGuid
dir_partition inode=33885
Directory /.Trashes
X 64 drwxr-xr-x 0 0 131072 1-Sep-2019 22:17 501
X 65 -rwxr-xr-x 0 0 4096 1-Sep-2019 22:17 ._501
dir_partition inode=64
Directory /.Trashes/501
Directory /.Trashes
dir_partition inode=276928
Directory /$RECYCLE.BIN
276929 -rwxr-xr-x 0 0 129 14-Nov-2018 04:13 desktop.ini
16 -rwxr-xr-x 0 0 66 1-Sep-2019 23:25 $IGZR1LS.Spotlight-V100
8 drwxr-xr-x 0 0 131072 8-Nov-2018 05:43 $RGZR1LS.Spotlight-V100
17 -rwxr-xr-x 0 0 52 1-Sep-2019 23:25 $IW64UQN.Trashes
33885 drwxr-xr-x 0 0 131072 8-Nov-2018 06:11 $RW64UQN.Trashes
dir_partition inode=8
Directory /.Spotlight-V100
9 drwxr-xr-x 0 0 131072 8-Nov-2018 05:43 Store-V2
10 drwxr-xr-x 0 0 131072 8-Nov-2018 05:43 Store-V1
12 -rwxr-xr-x 0 0 4160 20-Nov-2018 21:59 VolumeConfiguration.plist
dir_partition inode=9
Directory /.Spotlight-V100/Store-V2
13 drwxr-xr-x 0 0 131072 8-Nov-2018 05:43 3C4C8601-C210-4AE7-BE27-6715F2910E82
dir_partition inode=10
Directory /.Spotlight-V100/Store-V1
11 -rwxr-xr-x 0 0 348 8-Nov-2018 05:43 VolumeConfig.plist
dir_partition inode=29
Directory /LOST.DIR
dir_partition inode=30
Directory /Android
Directory /.Trashes
Directory /.Trashes/501/Android
Directory /.Trashes/501/LOST.DIR
Directory /.Trashes
dir_partition inode=41
Directory /cpy-rottr20yc
1103155845 -r-xr-xr-x 0 0 9613373745154621441 1-Jan-1980 01:10
2238350704 -r-xr-xr-x 0 0 8425674151901118674 1-Jan-1980 01:10
4153347 -rwxr-xr-x 0 0 5130726919158890838 1-Jan-1980 01:00 ĀȀĀ⊑?®ĀȀĀ
3531964541 -r-xr-xr-x 0 0 9619826891657724352 1-Dec-1982 00:26 ã¼¢Äè²ĔԀê¦è½íЅ䇀Øç¶—薀샒ÅÈ€ê¦è½íŠ…áŒå€ƒ7¨
X1103155845 dr-xr-xr-x 0 0 9650629003639390209 28-Feb-1949 12:30
21086418 -r-xr-xr-x 0 0 4738018302553432950 1-Jan-1980 01:10 ĀԀ︣튅䇀Øâ…藾샒ÅȀ︣튅㕆㔷瀮楬瑳Āâƒá€€ä¤·ç‘®ç‰¥æ…¶ç¬ãŸã ±
X 1 -rwxr-xr-x 0 0 18215093748813190912 5-Mar-1949 19:25 Ȁ階튋䇀ĔԀﳻ柬튌䇀ê˜î³£è±§ìƒ’ÅȀﳻ柬튌
X2168525312 -rwxr-xr-x 0 0 16861759527267517472 16-Jan-1980 21:00 ĀȀĀȀîà»’î‰î„¸ê§€è¿£î€¾è˜¼î§Ã¹î†£é˜«î§á‘ªî€€
dir_partition inode=1103155845
file_pread(5,256,buffer,5077278967(316045/254/41)) lseek err Invalid argument
file_pread(5,1,buffer,5077278967(316045/254/41)) lseek err Invalid argument
exFAT: Can't read directory cluster.
Directory /cpy-rottr20yc/
Directory /$RECYCLE.BIN/$RGZR1LS.Spotlight-V100
Directory /$RECYCLE.BIN/$RGZR1LS.Spotlight-V100/Store-V2
Directory /$RECYCLE.BIN/$RGZR1LS.Spotlight-V100/Store-V1
Directory /$RECYCLE.BIN/$RW64UQN.Trashes
Directory /$RECYCLE.BIN/$RW64UQN.Trashes/501
Directory /$RECYCLE.BIN/$RW64UQN.Trashes/501/Android
1 P HPFS - NTFS 114675 0 1 121599 254 63 111250125
NTFS at 114674/254/63
filesystem size 1842253809
mft_lcn 10521191
mftmirr_lcn 36
HPFS - NTFS 0 1 4 114674 254 63 1842253809
NTFS found using backup sector, blocksize=4096, 943 GB / 878 GiB
file_pread(5,2,buffer,1953505279(121600/20/20)) lseek err Invalid argument
file_pread(5,1,buffer,1953505279(121600/20/20)) lseek err Invalid argument
file_pread(5,2,buffer,1953506047(121600/32/32)) lseek err Invalid argument
file_pread(5,1,buffer,1953506047(121600/32/32)) lseek err Invalid argument
file_pread(5,2,buffer,1953504959(121600/15/15)) lseek err Invalid argument
file_pread(5,2,buffer,1953505022(121600/16/15)) lseek err Invalid argument
file_pread(5,2,buffer,1953505085(121600/17/15)) lseek err Invalid argument
file_pread(5,1,buffer,1953505280(121600/20/21)) lseek err Invalid argument
L HPFS - NTFS 0 1 4 114674 254 63 1842253809
Failed to open $MFT/$BITMAP: No such file or directory.
ntfs_mft_load(): Failed.
Failed to load $MFT: No such file or directory.
Failed to startup volume: No such file or directory.
Not an exFAT boot sector.
P HPFS - NTFS 0 1 4 114674 254 63 1842253809
1 P HPFS - NTFS 0 1 4 114674 254 63 1842253809
2 * HPFS - NTFS 114675 0 1 121599 254 63 111250125
Store new MBR code
Store new MBR code
New options :
Dump : No
Align partition: Yes
Expert mode : No
New options :
Dump : No
Expert mode : No
Partition table type: EFI GPT
Trying alternate GPT
Partition table type: None
P Unknown 0 0 1 121600 10 58 1953504688
Change partition type:
P NTFS 0 0 1 121600 10 58 1953504688
Directory /.Trashes
Directory /.Trashes
Directory /LOST.DIR
Directory /Android
Directory /.Trashes
Directory /.Trashes
mft_lcn 10521191
mftmirr_lcn 36
Store new MBR code
Store new MBR code
New options :
Dump : No
Expert mode : No
New options :
Dump : No
Expert mode : No
tabaquinho
just so you know, I updated the previous post with the log!
