photorec recovered a lot of eCryptfs files for me, and I'm trying post #5 from ...pic.php?t=7535
supplying it the passphrase from running a ecryptfs-unwrap-passphrase on the actual system, but then i get warnings like
WARNING: Based on the contents of [/root/.ecryptfs/sig-cache.txt],
it looks like you have never mounted with this key
before. This could mean that you have typed your
passphrase wrong.
even though i've copied/pasted the key, then i get this
mount: /home/username/Desktop/decrypted: wrong fs type, bad option, bad superblock on /home/username/Desktop/crypted, missing codepage or helper program, or other error.
Error mounting eCryptfs: [-1] Operation not permitted
The default settings were used on the encrypted home folder so it should be AES and 16 as advised to be checked in that other post, any ideas on what else could be the issue here?
decrypting eCryptfs files recovered by photorec
Re: decrypting eCryptfs files recovered by photorec
Please provide the exact command line you used.
Sorry, bad link, it's actually viewtopic.php?f=7&t=7535
Here is the command
sudo mount -t ecryptfs -o ecryptfs_passthrough=n,key=passphrase,ecryptfs_enable_filename_crypto=n,ecryptfs_key_bytes=16,ecryptfs_cipher=aes crypted decrypted
then when it prompts for the passphrase, I take the passphrase I copied from a ecryptfs-unwrap-passphrase and paste it in. then I get the following (put X's in some spots for privacy)
passphrase wrong.
Would you like to proceed with the mount (yes/no)? : yes
Would you like to append sig [xxxxxxxxxxxxxxxx] to
in order to avoid this warning in the future (yes/no)? : no
Not adding sig to user sig cache file; continuing with mount.
mount: /home/xxx/Desktop/decrypted: wrong fs type, bad option, bad superblock on /home/xxx/Desktop/crypted, missing codepage or helper program, or other error.
Check your system logs; visit <http://ecryptfs.org/support.html>
Here is the command
passphrase wrong.
The algo may be something other than aes and/or the ecryptfs_key_bytes may be different than 16.
Maybe it's possible to get the values use previously from log files...
The home directory was originally encrypted when Linux Mint was loaded, which I believe uses /usr/bin/ecryptfs-setup-private which has this in it:
CIPHER="aes"
KEYBYTES="16"
I'm not sure if there's a more accurate way to tell.
CIPHER="aes"
KEYBYTES="16"
Anything else I can try, or do you think I'm out of luck?
