Mac OS broken partition table in APFS with password
angelo306
#1 Post by angelo306 »
Hello Mr Grenier,
thank you for your wonderful applications. I have a MacBook Pro with a Samsung SSD of 501 GB. The drive crushed. The files should be there since PhotoRec found many files but without their names. Also the Drive is APFS with password.
I run TestDisk and I got the following:
Disk /dev/disk3 - 500 GB / 465 GiB - 976773167 sectors
 P EFI System                    40     409639     409600 [EFI System Partition]
>P Mac HFS                  2808634   31910715   29102082
 P Linux filesys. data    685036202  693246861    8210660 [L Nd ^Q n $o~S^C]
 P Mac HFS                975241448  976510983    1269536
                P=Primary  D=Deleted
Keys A: add partition, L: load backup, T: change type,
     Enter: to continue
HFS blocksize=67108864, 14 GB / 13 GiB
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
                P=Primary  D=Deleted
     Enter: to continue
HFS+ blocksize=4096 + Backup, 650 MB / 619 MiB
I want to ask you the following:
1)why there is a Linux partition though I did not have any Linux installed?
2)The first Mac HFS partition has a 67108864 blocksize and the 3rd Mac HFS partition is 512 size? What is the problem here?
I want to rebuild the partition table with gpt but when I put the numbers it does not mount..
Thank you in advance
