No Harddisk Found Topic is solved
blabla1903
No Harddisk Found
#1 Post by blabla1903 »
I am working on Ubuntu 18.04 . I deleted an important file with an extension .ipynb . I searched for similar cases and tried to use testdisk but it seems like I'm doing something wrong. Testdisk can not find any harddisk. I was going to make explicit the location of the device like it's been done in this case viewtopic.php?t=8161 but I don't know the exact location and fdisk -l doesn't work for me. It says :
fdisk -l
fdisk: cannot open /proc/partitions: No such file or directory
I also tried
df -Th
but don't know the which one to choose.
Ek Açıklama 2019-10-16 041443.png (11.9 KiB) Viewed 39645 times
Re: No Harddisk Found
fdisk, testdisk and photorec need to be run as root.
blabla1903
#3 Post by blabla1903 »
cgrenier wrote: 20 Oct 2019, 08:36 fdisk, testdisk and photorec need to be run as root.
The thing is that I can run them with "sudo" but testdisk can't find any harddisk.
Ek Açıklama 2019-10-24 143904.png (11.57 KiB) Viewed 39537 times
How about "lsblk -l"?
How is your total hard drive configuration like?
blabla1903
#5 Post by blabla1903 »
recuperation wrote: 24 Oct 2019, 13:57 How is your total hard drive configuration like?
I'm not quite sure what you are asking :? but I only have my local disk C: which is my ssd.
Ek Açıklama 2019-10-24 221237.png (8.55 KiB) Viewed 39520 times
#6 Post by recuperation »
Now I am confused. You are running Linux. "C:\" is a windows term. It seems to be mounted as the c-folder.
Where is your operating system?
There is lacking information about from where your Linux starts. Without devices there is no Linux starting.
blabla1903
#7 Post by blabla1903 »
recuperation wrote: 24 Oct 2019, 20:57 Now I am confused. You are running Linux. "C:\" is a windows term. It seems to be mounted as the c-folder.
Yes. My OS is windows 10 and I'm using Ubuntu(Windows subsystem for Linux) on windows 10.
#8 Post by recuperation »
I doubt that your Linux subsystem gives you full system control.
Try running the Windows version of Testdisk on Windows 10.
blabla1903
#9 Post by blabla1903 »
recuperation wrote: 25 Oct 2019, 05:23 I doubt that your Linux subsystem gives you full system control.
Finally, thanks a lot :D . I somehow managed to recover my file thanks to you. I wish I could have done this process on Ubuntu because this way ıt requires too many unnecessary steps.
#10 Post by recuperation »
I am glad to hear about every success story!
There is a possibility to mark threads as solved. I don't know if you can do that for your own thread or if Christophe Grenier has to do it.
