Recovering HFS+. Last step
retrorec
Re: Recovering HFS+. Last step
#11 Post by retrorec »
Sorry...
non-tried:    9223 PB
pct rescued:    0.00%, read errors:
This ones
Is it important?
Thank you for your replies.
#12 Post by recuperation »
retrorec wrote: 23 Oct 2019, 06:47 Sorry...
non-tried:    9223 PB
This ones
Is it important?
The non-tried area can not be bigger than your disk size of 2TB.
Your screenshot shows that you already duplicated 600 GB (not 60 GB as you said) out of 2 TB = 2000 GB which is 30%.
Both figures are wrong.
Ignore them and let the copy process finish. You can research these errors or file a bug report afterwards.
retrorec
#13 Post by retrorec »
recuperation wrote: 23 Oct 2019, 08:02
You are right. It was 600 GiB
Now...1548 GB, 2d 11h 20m, 6,8Mb/s, 85% aprox
     ipos:    1549 GB, non-trimmed:        0 B,  current rate:   6815 kB/s
     opos:    1549 GB, non-scraped:        0 B,  average rate:   7251 kB/s
non-tried:    9223 PB,  bad-sector:        0 B,    error rate:       0 B/s
  rescued:    1549 GB,   bad areas:        0,        run time:  2d 11h 20m
pct rescued:    0.00%, read errors:        0,  remaining time:         n/a
                              time since last successful read:          0s
Copying non-tried blocks... Pass 1 (forwards)
Ok. I will wait. Thank you.
retrorec
#14 Post by retrorec »
Finished
     ipos:    2000 GB, non-trimmed:        0 B,  current rate:   5199 kB/s
     opos:    2000 GB, non-scraped:        0 B,  average rate:   7242 kB/s
non-tried:        0 B,  bad-sector:        0 B,    error rate:       0 B/s
  rescued:    2000 GB,   bad areas:        0,        run time:  3d  4h 43m
                              time since last successful read:         n/a
Finished
sh-3.2#
retrorec
#15 Post by retrorec »
Thank you in davance.
Last two questions before proceed.
Ok. I am ready to proceed with the recovery (please see my first post if you need more information)
General steps:
1- I used Testdisk, with deep search (20 days about) to find lost partitions, and I found it
>D MS Data                     2048 3867961343 3867959296 [T2_B]
2- I used ddrescue to clon the disk (if something goes wrong with the rcovering with Testdisk)
Finished
Solution offered by cgreiner
cgrenier wrote: 20 Oct 2019, 10:14 When you see
use the arrow keys to switch this partition to P(rimary)
On next screen, choose Write, confirm, Quit
Remenber that I had four partitions. (please see my first post if you need more information)
Old partition table. I need to recover
It had FOUR partitions. GPT table with
1) EFI 200 MB
2) HFS+ 1844 GB (with data) !!!!!!!! i need to recover it
3) HFS+ 10 GB (not important)
4) HFS+ 10 GB (not important)
Some advice before proceed?
Question 1: Could I ignore the other three partitions and proceed to rewrite partition table as Prymary only for "MS Data" partition?
Question 2: Do you recommend me to act over the cloned disk? I mean, to repeat all steps in the cloned disk: scanning it and trying to repair cloned partition table?
Thanks a lot
#16 Post by recuperation »
retrorec wrote: 25 Oct 2019, 08:38 Question 1: Could I ignore the other three partitions and proceed to rewrite partition table as Prymary only for "MS Data" partition?
You can.
Modifications of a partition table in GPT format are not as risky as modifying the old style ones.
Nevertheless, I would recommend everybody to produce a duplicate of a failing drive and to duplicate that again.
You would work on the second copy and you always have the option to restore the original content using your first copy.
retrorec
#17 Post by retrorec »
recuperation wrote: 25 Oct 2019, 09:58
ok!!! So...
I will reply the process in the cloned disk
Cloned disk 1863 GiB
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
Disk /dev/rdisk4 - 2000 GB / 1863 GiB - 3907029168 sectors
 1 P EFI System                    40     409639     409600 [EFI System Partition] [EFI]
 2 P Mac HFS                   409640 3906766983 3906357344
 [  Quit  ]  [ Return ] >[Deeper Search]  [ Write  ]
                          Try to find more partitions
It seems identical.
New partition table and searching on process 00%
See you in two weeks about :)
retrorec
#18 Post by retrorec »
Hello again
After 12 days scanning the cloned 2TB HDD, I was ready to try to rescue the partition table.
Both 2TB HDDs seems identicals. Nice
 D EFI System                    40     409639     409600 [EFI System Partition] [EFI]
 D EFI System                    46     409645     409600 [EFI System Partition] [EFI]
>P MS Data                     2048 3867961343 3867959296 [T2_B]
 D Mac HFS                   409640 3906766983 3906357344
 D Mac HFS                   528920 3906886263 3906357344
 D Mac HFS                   528992 3906886335 3906357344
                P=Primary  D=Deleted
     Enter: to continue
NTFS found using backup sector, blocksize=4096, 1980 GB / 1844 GiB
 1 P MS Data                     2048 3867961343 3867959296 [T2_B]
Write partition table, confirm ? (Y/N)
I select "P" and Write and this is the result
Status: Bad
Warning: number of heads/cylinder mismatches 255 (NTFS) != 1 (HD)
Warning: number of sectors per track mismatches 63 (NTFS) != 1 (HD)
Status: OK
Sectors are not identical.
 [  Quit  ]  [  List  ] >[Backup BS]  [Rebuild BS]  [  Dump  ]
                    Copy backup boot sector over boot sector
Status: Bad
What now?
"Rebuild BS", "Write" and reboot?
retrorec
#19 Post by retrorec »
Please help. I am trying to write a new partición table
(see previous post) but TestDisk says:
Status: Bad
What now?
Thank you in advance.
