I need to create a disk image of my ipad on my MacBook (running Mojave) so I can retrieve lost photos with PhotoRec...
I followed the instructions given here: https://www.cgsecurity.org/wiki/Recover ... _an_iPhone
These instructions are for the iphone but I believe it should work for the ipad (V1 ipad, no camera)
when I run the command from the terminal on the ipad:
dd if=/dev/rdisk0 bs=4096 | ssh -C CDC@192.168.1.10 'dd of=iphone.img'
I get the following::
dd: reading `/dev/disk0' : Invalid argument
0+0 records in
0+0 records out
0 bytes (0 B) copied, 0.093975 s, 0.0 kb/s
Can someone tell me what I did wrong?
it does create a iphone.img file on my Macbook HD with 0 bytes...
ipad DD not working...
Re: ipad DD not working...
The source "/dev/rdisk0" is wrong. The "mount" command may display the correct one.
Thanks , I typed in mount and got the following...
/dev/disk0s1s1 on / (hfs, local, journaled, noatime)
devfs on /dev (devfs, local, nobrowse)
/dev/disk0s1s2 on /private/var (hfs, local, journaled, noatime, protect)
Hope this is helpful.
Jailbroke with Cydia which I believe has BSD as far as I could find/read... perhaps not? maybe you could point me toward how to find and install BSD as I can find no such thing... Open SSH and Terminal are on the ipad...
DD was something I read was part of my Macbook OS, perhaps it is something I am missing?
I have run:
dd if=/dev/rdisk01s1 bs=4096 | ssh -C CDC@192.168.1.10 'dd of=iphone.img'
and
Run dd if=/dev/rdisk01s2 bs=4096 | ssh -C CDC@192.168.1.10 'dd of=iphone.img'
unfortunately both gave me the Invalid argument... and created a 0 byte file on my macbook HD...
Anyone know what to check next?
and
Ok I found this new guide... https://forums.modmy.com/file-mods-f...roken-mac.html
It is basically the same except I run things through terminal on my mac... It recommends using " bs=4096kb " instead of "4096"... this did not work either but another webpage recommended replacing with "bs=1M" ... THIS WORKED!!!
currently in progress... will report back...
