Disque RAW reconnu en FAT32 et non NTFS
MasterOwl
#1 Post by MasterOwl »
Bonjour à tous,
Ce weekend j'ai nettoyé le PC et en rallumant j'ai un disque qui est passé en RAW.
Voici le log de testdisk
Tue Nov  5 21:23:48 2019
TestDisk 7.2-WIP, Data Recovery Utility, July 2019
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdd)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive3)=2000398934016
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=255540922880
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=3000591450112
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=2000396746752
Disk /dev/sda - 256 GB / 238 GiB - CHS 31130 255 63, sector size=512 - SanDisk SDSSDH2256G, S/N:130763402151, FW:X211200
Disk /dev/sdb - 3000 GB / 2794 GiB - CHS 364801 255 63, sector size=512 - Hitachi HDS5C3030BLE630, S/N:MC49215X03356A, FW:MZ6OAAB0
Disk /dev/sdc - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARX-00PASB0, S/N:WD-WCAZAA424383, FW:51.0AB51
Disk /dev/sdd - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512 - WDC WD20EARS-00MVWB0, S/N:WD-WMAZA3462839, FW:51.0AB51
Drive F: - 2000 GB / 1863 GiB - CHS 243201 255 63, sector size=512
Disk /dev/sdc - 2000 GB / 1863 GiB - WDC WD20EARX-00PASB0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=3907029167 (expected 3907029167)
hdr_lba_start=34
hdr_lba_end=3907029134
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
 1 P MS Reserved                   34      32767      32734 [Microsoft reserved partition]
hdr_size=92
hdr_lba_self=1
hdr_lba_start=34
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
file_pread(6,2,buffer,3907031039(243201/110/45)) lseek err Invalid argument
file_pread(6,1,buffer,3907031039(243201/110/45)) lseek err Invalid argument
Photorec retrouve bien des fichiers mais j'aimerai plutot réparer le disk. Sachant que c'était une partition NTFS à la base et que testdisk m'affiche ca
2019-11-05 21_25_20-E__testdisk-7.2-WIP_testdisk_win.exe.png (24.87 KiB) Viewed 20689 times
Pouvez vous me dire la marche à suivre ? Avant d'utiliser les mauvaises options.
Merci d'avance :mrgreen:
Re: Disque RAW reconnu en FAT32 et non NTFS
En choisissant EFI GPT, que donne TestDisk, Analyse, Quick Search, Deeper Search ?
Si la partition est retrouvée, il faudrait la passer en P(rimary) et choisir sur l'écran suivant Write, confirmer puis "Quit".
MasterOwl
#3 Post by MasterOwl »
Bonjour cgrenier,
Merci pour la réponse rapide ! ;)
Je viens de lancer le quicksearch à l'instant et lancerai le deepsearch ensuite.
C'est un peu long (disque de 2TO). Je posterai l'avancer dans la journée !
MasterOwl
#4 Post by MasterOwl »
Après 5h de quick search 16% d'effectué
2019-11-06 13_44_41-Disque RAW reconnu en FAT32 et non NTFS - cgsecurity.org.png
2019-11-06 13_44_41-Disque RAW reconnu en FAT32 et non NTFS - cgsecurity.org.png (26.13 KiB) Viewed 20663 times
Je ne sais pas si c'est normal que cela prenne autant de temps.
MasterOwl
#5 Post by MasterOwl »
Toujours en cours mais avec des warnings
2019-11-07 15_23_55-.png (69.47 KiB) Viewed 20609 times
MasterOwl
#6 Post by MasterOwl »
Voilà après le quick search
2019-11-08 09_17_49-.png (29.89 KiB) Viewed 20572 times
J'ai l'impression que c'est dead :D
Après avoir cliquer sur continue
2019-11-08 09_37_19-E__testdisk-7.2-WIP_testdisk_win.exe.png (71.49 KiB) Viewed 20571 times
MasterOwl
#7 Post by MasterOwl »
Quand j'essaie de lister les fichiers voici le résultat (sur les deux premiers "MS DATA"
2019-11-08 15_15_49-E__testdisk-7.2-WIP_testdisk_win.exe.png (16.55 KiB) Viewed 20542 times
Quelles sont les prochaines étapes ?
Merci d'avance
#8 Post by recuperation »
Examinez le contenu de chaque partition avec la touche "P".
MasterOwl
#9 Post by MasterOwl »
Aucun fichiers à part des dossiers "System information" et "EFI".
Toutes les partitions noté MS DATA sont bien reconnu NTFS mais il est marqué "Can't open filesystem. Filesystem seems damaged"
Donc il reconnait bien les partitions NTFS même si à la base j'en avais qu'une seule sur ce disque... Mais il n'arrive pas à lister les fichiers.
#10 Post by recuperation »
Dans ce cas il ne reste que Photorec pour rassembler les restes des fichiers.
