Suddenly copy done 0 ok
anonimous
#1 Post by anonimous »
Have hdd with lst partition table. Partitions successfully found with testdisk.
The I successfully copied few big files from one of the partitions.
And then I decide to copy files from another partition(I think somewhere at following steps roots of the problem).
I comeback to partitions list(probably by pressing esc button), and tried to copy files but now I get "copy done 0 ok 0 failed"
Okay, I thought, something wrong with this partition then. But after I return to previous partition I get the same error on it. On partition I sucessfully copied gigabytes of data few minutes ago.
What can cause this behaviour? Maybe because Zi was pressing wrong hotkeys or exiting testdisk by just pressing X on the terminal?
