Photorec to recover files in an ext4 directory identified with its inode nr
fepeacock
#1 Post by fepeacock »
I would like to recover deleted files from a directory on an ext4 file system. I would like to avoid the full scan of the partition and only recover from the existing directory.
I have been advised to issue the following command: "photorec /cmd device ext2_inode,inode_nr,search" where the device is the block device of the partition and inode_nr is the inode of the directory.
I have tried this with a number of directories and sub-directories (as well as different partitions) but it seems to recover files from other locations or none at all.
Am I using this correctly? Could anyone please help?
Thanks,
Frank
Re: Photorec to recover files in an ext4 directory identified with its inode nr
PhotoRec will recover files from the group holding the specified inode. Different inodes may have the same group. A group may contains data from several directories/files.
