Recovery of a PVR fat32 Disk
DeveloperChris
#1 Post by DeveloperChris »
I have searched for the answer to this and so far have had no luck
Can testdisk use non standard sector and cluster sizes when searching a fat32 disk?
I have a corrupted 500GB western digital drive (it appears they have low tolerance to heat)
The drive is from a "beyonwiz" PVR
it uses a Cluster size of 512Kb
and a Sector size of 4096
It is recognised as a Fat32 LBA
Disk /dev/sdc - 500 GB / 465 GiB - CHS 7601 255 63
> 1 P FAT32 LBA                0   1  1 60800 254 63  976768002
After setting the sector size to 4096 and then analysing I get this
Invalid FAT boot sector
After the analysis run (no to vista) No partition is found
What more can I do?
I am currently running fsck on a dd_rescue image of the disk but it is faltering on
Bad short file name (�@&!@Q*\200.L4\227).
  Auto-renaming it.
  Renamed to FSCK0009.823
As you can see I am up to 9823 files. I am concerned its going to rename every file on the disk making it impossible for me to restore it
Any assistance would be greatly appreciated
DC
Re: Recovery of a PVR fat32 Disk
It's not possible that the cluster size is smaller than a sector?
Would it be possible to use TestDisk6.14WIP-32bit and confirm through until you see your disk selction.
Select your disk and confirm through until Analyse.
Please copy and paste the content of your testdisk.log in your testdisk folder.
The log file displays the sector size of your disk.
Video or HDD recorder often using Linux or UNIX file systems.
My one for example uses xfs file system.
DeveloperChris
#3 Post by DeveloperChris »
Hi Fiona
Thankyou
The PVR uses fat32. The cluster size according to the beyonwiz forum is 512kB and the sector size is 4096 bytes beyond that I do not know much.
The linux kernel in the beyonwiz is an 2.4.x. but I do not know much about the differences between kernel revisions.
I am using knoppix livecd (7.02) to run testdisk as windows does not understand the fat format at all. as it does not recognise cluster sizes larger than 32kB so all the disk recovery tools I tried borked.
DeveloperChris
Wed Aug  8 07:03:54 2012
OS: Linux, kernel 3.4.4 (#14 SMP PREEMPT Sat Jun 23 20:07:21 CEST 2012) i686
Compiler: GCC 4.6
Compilation date: 2012-01-16T23:06:01
ext2fs lib: 1.42.4, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: none
/dev/sda: size       488397168 sectors
/dev/sda: user_max   488397168 sectors
/dev/sda: native_max 488397168 sectors
/dev/sda: dco        488397168 sectors
/dev/sdb: size       976773168 sectors
/dev/sdb: user_max   976773168 sectors
/dev/sdb: native_max 976773168 sectors
/dev/sdb: dco        976773168 sectors
/dev/sdc: LBA, HPA, LBA48, DCO support
/dev/sdc: size       976773168 sectors
/dev/sdc: user_max   976773168 sectors
/dev/sdc: native_max 976773168 sectors
/dev/sdc: dco        976773168 sectors
/dev/sr0 is not an ATA disk
Disk /dev/sda - 250 GB / 232 GiB - CHS 30401 255 63, sector size=512 - ST3250823AS, S/N:4ND21DXT, FW:3.03
Disk /dev/sdb - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - Hitachi HDS721050CLA362, S/N:JPB530HN3HBTVB, FW:JP2OA3EA
Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - WDC WD5000AVJB-63J1A0, S/N:WD-WCASZ0989363, FW:05.04E05
Disk /dev/sdd - 888 GB / 827 GiB - CHS 107982 255 63, sector size=512 - Seagate FreeAgent Go, FW:0148
Disk /dev/sr0 - 726 MB / 692 MiB - CHS 354704 1 1 (RO), sector size=2048 - HL-DT-ST DVD-RW_GSA-H11N, S/N:04D84334797A, FW:JH02
Disk /dev/sdc - 500 GB / 465 GiB - WDC WD5000AVJB-63J1A0
Analyse Disk /dev/sdc - 500 GB / 465 GiB - CHS 60801 255 63
check_FAT: Incorrect number of bytes per sector 4096 (FAT) != 512 (HD)
test_FAT()
sector_size  4096
cluster_size 128
reserved     128
fats         2
dir_entries  0
sectors      0
media        F8
fat_length   0
secs_track   63
heads        255
hidden       0
total_sect   122096000
Ask the user for vista mode
search_vista_part: 0
DeveloperChris
#4 Post by DeveloperChris »
Bump
Any ideas what I can do?
#5 Post by Fiona »
FAT ist a Standard.
Sector size is usually 512 Bytes.
TestDisk recognizes your sector size as 512 Bytes only;
If you're abolutely sure, you can use the menu geometry to increase your sector size.
4 KB sector size often reacts different.
If internally plugged in, 4 KB sector size disks won't boot.
The BIOS emulates your disk as 512 Byte sector size disk.
Some information about 4 K. sectors in this post also;
http://forum.cgsecurity.org/phpBB3/inco ... t1017.html
Until yet, you can resize your sector size using the menu geometry.
Please don't use the menu "Write" if your not 100 % sure.
So you can at least use it as a diagnose and it will help determine your status of your disk.
Also if you resize your sector size, please watch that message which TestDisk displays at the bottom of the display.
Please let me know, do you get different results?
