Cannot recover partition
mattr
#1 Post by mattr »
thanks for your help, i have read a few of the other posts from people having the same issue but i don't know if mine is similar, so instead of trying options without knowing what i'm doing, i'm posting my log here with hope that someone can help me.
Things to consider:
The disk is a 1TB Western Digital My Passport. I understand that the disks are automatically encrypted. What I did was to unlock it first, using WD_UNLOCKER, then I ran ddrescue to put the entire contents on a Toshiba 1TB drive. Because the Toshiba is the same size, ddrescue was not able to entirely copy the disk, only 99% of it. So that means when I put the drive in, there is a partition found because WD_UNLOCKER file is there. After it's unlocked, the unlocked drive is unusable.
Then I ran testdisk on the Toshiba drive copy, and I didn't go far.
I'm not sure if I should run testdisk on the original My Passport because of the encryption, or are the errors shown not related? Is it because the Toshiba only has 99% of the copy?
Thanks for your help!
Tue Feb 18 13:45:27 2020
TestDisk 7.2-WIP, Data Recovery Utility, January 2020
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(/dev/sdb)=1000204883968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\PhysicalDrive1)=1000204883968
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=497866382336
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=1000202043392
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST500LM021-1KJ152, S/N:W62LA47Z, FW:0002YXM1
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA External USB 3.0, S/N:20180525004283F, FW:5438
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA External USB 3.0
BAD_RS LBA=2048 63
Invalid NTFS or exFAT boot
1 * HPFS - NTFS 0 32 33 121601 25 24 1953519616
Bad relative sector.
BAD_RS LBA=4096 2048
HPFS - NTFS 0 65 2 121597 70 9 1953456128
file_pread(5,2,buffer,1953525759(121601/90/25)) lseek err Invalid argument
file_pread(5,14,buffer,1953525762(121601/90/28)) lseek err Invalid argument
file_pread(5,3,buffer,1953525776(121601/90/42)) lseek err Invalid argument
file_pread(5,3,buffer,1953525823(121601/91/26)) lseek err Invalid argument
file_pread(5,8,buffer,1953525839(121601/91/42)) lseek err Invalid argument
file_pread(5,11,buffer,1953525886(121601/92/26)) lseek err Invalid argument
file_pread(5,2,buffer,1953527808(121601/122/58)) lseek err Invalid argument
* HPFS - NTFS 0 65 2 121597 70 9 1953456128
Not an exFAT boot sector.
1 * HPFS - NTFS 0 65 2 121597 70 9 1953456128
BAD_RS LBA=1591320933 6200934
FAT32 LBA 99055 37 28 282751 53 10 2951077231
This partition ends after the disk limits. (start=1591320933, size=2951077231, end=4542398163, disk end=1953525164)
BAD_RS LBA=4598211085 6557393
file_pread(5,1,buffer,4598211085(286225/102/35)) lseek err Invalid argument
HPFS - NTFS 286225 102 35 486984 157 62 3225196828
This partition ends after the disk limits. (start=4598211085, size=3225196828, end=7823407912, disk end=1953525164)
NTFS at 121601/25/24
filesystem size 1953519616
mftmirr_lcn 2
NTFS found using backup sector, blocksize=4096, 1000 GB / 931 GiB
The harddisk (1000 GB / 931 GiB) seems too small! (< 4005 GB / 3730 GiB)
$MFT has invalid magic.
ntfs_mft_load(): Failed.
Change partition type:
BAD_RS LBA=2048 63
ntfs_boot_sector
NTFS at 0/32/33
filesystem size 1 1953519616
sectors_per_cluster 0 8
mft_lcn 0 786432
mftmirr_lcn 0 2
clusters_per_mft_record 0 -10
clusters_per_index_record 0 1
Status: Bad
Status: OK
Sectors are not identical.
Re: Cannot recover partition
mattr wrote: 19 Feb 2020, 18:35 The disk is a 1TB Western Digital My Passport. I understand that the disks are automatically encrypted. What I did was to unlock it first, using WD_UNLOCKER, then I ran ddrescue to put the entire contents on a Toshiba 1TB drive. Because the Toshiba is the same size, ddrescue was not able to entirely copy the disk, only 99% of it. So that means when I put the drive in, there is a partition found because WD_UNLOCKER file is there. After it's unlocked, the unlocked drive is unusable.
Please show your ddrescue command string.
mattr
#3 Post by mattr »
ddrescue --force /dev/sdc /dev/sdb
/dev/sdc is the WD My Passport
/dev/sdb is the Toshiba.
I didn't add any parameter, I ran it under a virtualbox running peppermint, it was showing 0 read errors, 99% done because of lack of disk space. I understand that I need 5% more than the original disk so I was wondering if this was my issue with testdisk, or if it was not related. I can redo the ddrescue with a log and parameters if needed.
I also ran gsmartcontrol and there were no errors.
Thank you :)
mattr wrote: 20 Feb 2020, 02:37 ddrescue --force /dev/sdc /dev/sdb
Thank you :)
There is no WD drive in your log file!
If you copy directly from device to device ddrescue is copying sector-wise.
The target has to be at least as large as the source.
Depending on how your virtualized environment redirects such a transaction into a file (on your target???) you need additional space.
I have only little experience with virtualized environments. I personally would avoid that additional operating system layer in case of recovery.
Use a logfile when running ddrescue.
#5 Post by recuperation »
Thank you :)
In a real (not virtual) environment a target that is having the same size as the source is sufficiently large.
mattr
#6 Post by mattr »
the log file was created with testdisk running on the Toshiba after the ddrescue was done. I was under the impression that it's best not to disturb the broken disk too much that's why i made the copy. I will try to copy again to a larger drive, or do you suggest I run testdisk directly on the WD after I unlock it and therefore avoid the ddrescue part?
Thanks!
#7 Post by recuperation »
mattr wrote: 20 Feb 2020, 22:07 Hi,
ddrescue has its own logfile that enables you to pause and continue the duplication process.
Thanks!
Thanks for explaining what your real problem is as this thread started as a copy job problem.
Don't stress a possibly broken drive.
By duplicating the drive you simultaneously solve the encryption issue and the health issue.
mattr
mattr
#8 Post by mattr »
the log i sent in my first post was the log of testdisk running against the copy, on the Toshiba, I was trying to recover the partitions I lost on the WD. I will try again with a larger disk to make sure ddrescue has enough space to copy the WD to a new disk.
#9 Post by recuperation »
Duplicate the whole drive.
