I am a new user of your wonderful utilities so excuse me my possible misunderstanding.
When using Photorec version 7.2 i am able to recover my documents, but their original names for some reason are lost.
For example:
- Original file "MyDocument.xlsx" recovered as f0301856.xlsx
Is this an expected behaviour or i am doing something wrong? Maybe outdated version of Photorec?
Thanks
Photorec files recovered but lost names
Re: Photorec files recovered but lost names
It's the expected behaviour.
TestDisk's Undelete can recover the original filenames, PhotoRec can't.
TestDisk can undelete files from FAT12/16/32, NTFS, exFAT and ext2, PhotoRec isn't limited to these filesystem and can work even if the filesystem is corrupted.
PhotorecUsr
Thank you for response. Regarding to inability to recover original filenames in Photorec - is it some technical limitation of application design or you simply had no time yet to implement this feature and maybe planning it in further releases? Just interesting, because i saw that other recovery utilities were able to recover file names during deep scanning
https://www.cgsecurity.org/wiki/PhotoRec
It's not a bug. It's a feature of a well-defined search strategy.
Other recovery software products are working differently.
=> no metadata evaluation => no file namesPhotoRec ignores the file system and goes after the underlying data, so it will still work even if your media's file system has been severely damaged or reformatted.
