I'm trying to recover a hard drive that somehow set itself to a RAW file system, crystaldiskinfo also said it had 199 pending sector count errors. I ran ddrescue on it to a new 1TB HDD, but at 97% it said there was one month remaining so I stopped the process there, knowing that there was a log file if I wanted to resume (not sure if this was a mistake).
The new HDD is now in RAW and I want to see if I can recover the clone that ddrescue made. Testdisk comes up with the error "Error: size boot_sector > partition".
I'm a little confused on how to proceed. Should I just let ddrescue run (I fear that the estimate to completion will keep growing)?
Any help would be much appreciated. The data on the hard drive isn't critical but would be nice to be able to recover.
Error: size boot_sector > partition on RAW file system
Re: Error: size boot_sector > partition on RAW file system
Please copy and paste the testdisk.log file content.
Tue Mar 31 23:03:13 2020
OS: Linux, kernel 5.3.0-40-generic (#32~18.04.1-Ubuntu SMP Mon Feb 3 14:05:59 UTC 2020) x86_64
Compiler: GCC 7.2
ext2fs lib: 1.44.1, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size 250069680 sectors
/dev/sda: user_max 250069680 sectors
/dev/sda: native_max 250069680 sectors
/dev/sda: dco 250069680 sectors
Disk /dev/sda - 128 GB / 119 GiB - CHS 15566 255 63, sector size=512 - SAMSUNG MZ7TY128HDHP-000L1, S/N:S2YPNB0H897418, FW:MAT05L0Q
Disk /dev/sdb - 1000 GB / 931 GiB - CHS 121601 255 63, sector size=512 - TOSHIBA External USB 3.0, FW:5438
Disk /dev/sdb - 1000 GB / 931 GiB - TOSHIBA External USB 3.0
Partition table type: EFI GPT
hdr_size=92
hdr_lba_self=1
hdr_lba_alt=1953458175 (expected 1953525163)
hdr_lba_start=34
hdr_lba_end=1953458142
hdr_lba_table=2
hdr_entries=128
hdr_entsz=128
1 P MS Data 2048 1953456127 1953454080
Error: size boot_sector 1953520816 > partition 1953454080
NTFS at 0/32/33
filesystem size 1953520816
mftmirr_lcn 2
NTFS part_offset=1048576, part_size=1000202657792, sector_size=512
NTFS at 0/32/33
mftmirr_lcn 2
MS Data 2048 1953522863 1953520816
P MS Data 2048 1953522863 1953520816
Hint for advanced users. dmsetup may be used if you prefer to avoid to rewrite the partition table for the moment:
echo "0 1953520816 linear /dev/sdb 2048" | dmsetup create test0
1 P MS Data 2048 1953522863 1953520816
