I have installed TestDisk with Homebrew but when I try to run PhotoRec i get the error :
zsh: bad CPU type in executable: /Users/workstation/Desktop/testdisk-7.1/photorec
I get the same error when trying to run TeskDisk as well.
I am using a 64bit mac with Catalina version 10.15.4
Thanks in advance!
Re: bad CPU type in executable
Use the testdisk version installed by brew instead of using the version manually downloaded .
littleporcelaine
Hi..I am still facing an as the OP's problem. Sorry to butt in.
but I am really on my wits end. How do I use the testdsik version by brew? I am not techy and I am having
confusions with some jargons. can you explain more about this? Thank you!
