Android deleted files recovery
Recuvo
#1 Post by Recuvo »
Hello! I want to recover my Android deleted files with Photorec. I have installed Testdisk through Termux but they don't detect any disk. How can I use Photorec (or Testdisk) in Android?
Thanks in advance!!
Re: Android deleted files recovery
PhotoRec will only work if your phone is rooted.
Even if you phone is rooted, it's easier to copy the internal memory to a remote computer and run photorec on the computer on the phone image.
Note that encryption may be used, so the files you want to recover may not be available.
