STATUS BS:Bad,Backup BS:Bad, SECTORS ARE IDENTICAL
mlamba91
#1 Post by mlamba91 »
plz help me,one partition of my internal hdd had gone RAW
CHKDSK not working
When i try to analyse it says "cant open filesystem,filesystem seems damaged"
When i select "Rebuild BS",it searches for MFT and after that same status reappears.
PLZ PLZ HELP
Re: STATUS BS:Bad,Backup BS:Bad, SECTORS ARE IDENTICAL
Can you post the testdisk.log file content ?
Is your partition protected using Disklocker ?
mlamba91
#3 Post by mlamba91 »
it was not password protected,i dont know about log file,where to find?
any suggestion on what should i do?
yeah i got this one file
Fri Apr 17 00:09:51 2020
TestDisk 7.2-WIP, Data Recovery Utility, January 2020
OS: Windows 8 (9200)
Compiler: GCC 7.4, Cygwin32 3000.3
ext2fs lib: 1.45.3, ntfs lib: 10:0:0, reiserfs lib: none, ewf lib: 20140608, curses lib: ncurses 6.0
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\C:)=52427902464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\E:)=31453438464
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\F:)=125830301184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\G:)=125830301184
disk_get_size_win32 IOCTL_DISK_GET_LENGTH_INFO(\\.\H:)=163395154944
filewin32_getfilesize(\\.\I:) GetFileSize err Incorrect function.
filewin32_setfilepointer(\\.\I:) SetFilePointer err Incorrect function.
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - ST9500325AS, S/N:S2WS89WS, FW:0011LVM1
Disk /dev/sda - 500 GB / 465 GiB - ST9500325AS
NTFS at 0/1/1
check_part_i386 3 type 12: no test
FAT32 at 6374/1/1
Info: size boot_sector 61432497, partition 61432497
FAT1 : 2786-17776
FAT2 : 17777-32767
start_rootdir : 32768 root cluster : 2
Data : 32768-61432479
sectors : 61432497
cluster_size : 32
no_of_cluster : 1918741 (2 - 1918742)
fat_length 14991 calculated 14991
NTFS at 10198/1/1
NTFS at 40794/1/1
get_geometry_from_list_part_aux head=255 nbr=18
get_geometry_from_list_part_aux head=8 nbr=3
1 * HPFS - NTFS 0 1 1 6373 254 63 102398247
NTFS, blocksize=4096, 52 GB / 48 GiB
2 E extended LBA 6374 0 1 60658 254 63 872088525
5 L FAT32 6374 1 1 10197 254 63 61432497 [NO NAME]
FAT32, blocksize=16384, 31 GB / 29 GiB
X extended 10198 0 1 25495 254 63 245762370
6 L HPFS - NTFS 10198 1 1 25495 254 63 245762307
NTFS, blocksize=4096, 125 GB / 117 GiB
X extended 25496 0 1 40793 254 63 245762370
7 L HPFS - NTFS 25496 1 1 40793 254 63 245762307
X extended 40794 0 1 60658 254 63 319131225
8 L HPFS - NTFS 40794 1 1 60658 254 63 319131162
NTFS, blocksize=4096, 163 GB / 152 GiB
3 P Compaq Diagnostics 60659 245 3 60801 80 63 2270896
ntfs_boot_sector
filesystem size 1
sectors_per_cluster 0
mft_lcn 0
mftmirr_lcn 0
clusters_per_mft_record 0
clusters_per_index_record 0
Status: Bad
Status: Bad
Sectors are identical.
