J'ai un disque dur de 1 To qui n'est pas en bon état:
smartctl 6.6 2016-05-31 r4324 [x86_64-linux-4.15.0-96-generic] (local build)
Copyright (C) 2002-16, Bruce Allen, Christian Franke, www.smartmontools.org
Model Family:     Toshiba 2.5" HDD MQ01ABD...
Device Model:     TOSHIBA MQ01ABD100
Serial Number:    Y5OYTNFVT
LU WWN Device Id: 5 000039 6a2089c32
Firmware Version: AX003J
User Capacity:    1 000 204 886 016 bytes [1,00 TB]
Sector Sizes:     512 bytes logical, 4096 bytes physical
Rotation Rate:    5400 rpm
Form Factor:      2.5 inches
Device is:        In smartctl database [for details use: -P show]
ATA Version is:   ATA8-ACS (minor revision not indicated)
SATA Version is:  SATA 3.0, 6.0 Gb/s (current: 6.0 Gb/s)
Local Time is:    Fri Apr 17 09:51:38 2020 CEST
SMART support is: Enabled
General SMART Values:
Offline data collection status:  (0x00)	Offline data collection activity
					was never started.
					Auto Offline Data Collection: Disabled.
Self-test execution status:      (   0)	The previous self-test routine completed
					been run.
data collection: 		(  120) seconds.
capabilities: 			 (0x5b) SMART execute Offline immediate.
					command.
					Self-test supported.
					No Conveyance Self-test supported.
SMART capabilities:            (0x0003)	Saves SMART data before entering
					power-saving mode.
Error logging capability:        (0x01)	Error logging supported.
Short self-test routine
recommended polling time: 	 (   2) minutes.
Extended self-test routine
recommended polling time: 	 ( 232) minutes.
SCT capabilities: 	       (0x003d)	SCT Status supported.
					SCT Data Table supported.
ID# ATTRIBUTE_NAME          FLAG     VALUE WORST THRESH TYPE      UPDATED  WHEN_FAILED RAW_VALUE
  1 Raw_Read_Error_Rate     0x000b   100   100   050    Pre-fail  Always       -       0
  2 Throughput_Performance  0x0005   100   100   050    Pre-fail  Offline      -       0
  3 Spin_Up_Time            0x0027   100   100   001    Pre-fail  Always       -       1437
  4 Start_Stop_Count        0x0032   100   100   000    Old_age   Always       -       5506
  5 Reallocated_Sector_Ct   0x0033   100   100   050    Pre-fail  Always       -       10400
  7 Seek_Error_Rate         0x000b   100   100   050    Pre-fail  Always       -       0
  8 Seek_Time_Performance   0x0005   100   100   050    Pre-fail  Offline      -       0
  9 Power_On_Hours          0x0032   095   095   000    Old_age   Always       -       2157
 10 Spin_Retry_Count        0x0033   208   100   030    Pre-fail  Always       -       0
 12 Power_Cycle_Count       0x0032   100   100   000    Old_age   Always       -       1636
191 G-Sense_Error_Rate      0x0032   100   100   000    Old_age   Always       -       1764
192 Power-Off_Retract_Count 0x0032   100   100   000    Old_age   Always       -       26
193 Load_Cycle_Count        0x0032   099   099   000    Old_age   Always       -       11051
194 Temperature_Celsius     0x0022   100   100   000    Old_age   Always       -       29 (Min/Max 9/54)
196 Reallocated_Event_Count 0x0032   100   100   000    Old_age   Always       -       202
197 Current_Pending_Sector  0x0032   100   100   000    Old_age   Always       -       1928
198 Offline_Uncorrectable   0x0030   100   100   000    Old_age   Offline      -       0
199 UDMA_CRC_Error_Count    0x0032   200   200   000    Old_age   Always       -       0
220 Disk_Shift              0x0002   100   100   000    Old_age   Always       -       0
222 Loaded_Hours            0x0032   096   096   000    Old_age   Always       -       1983
223 Load_Retry_Count        0x0032   100   100   000    Old_age   Always       -       0
224 Load_Friction           0x0022   100   100   000    Old_age   Always       -       0
226 Load-in_Time            0x0026   100   100   000    Old_age   Always       -       184
240 Head_Flying_Hours       0x0001   100   100   001    Pre-fail  Offline      -       0
SMART Error Log Version: 1
ATA Error Count: 604 (device log contains only the most recent five errors)
	CR = Command Register [HEX]
	FR = Features Register [HEX]
	ER = Error register [HEX]
	ST = Status register [HEX]
Error 604 occurred at disk power-on lifetime: 2157 hours (89 days + 21 hours)
  ER ST SC SN CL CH DH
  40 51 08 c8 37 3a 40  Error: UNC 8 sectors at LBA = 0x003a37c8 = 3815368
  CR FR SC SN CL CH DH DC   Powered_Up_Time  Command/Feature_Name
  25 da 08 c8 37 3a 40 00      00:17:37.382  READ DMA EXT
  25 da 08 c8 37 3a 40 00      00:17:33.463  READ DMA EXT
  25 da 08 c0 37 3a 40 00      00:17:33.463  READ DMA EXT
  25 da 08 b8 37 3a 40 00      00:17:33.463  READ DMA EXT
  25 da 08 b0 37 3a 40 00      00:17:33.462  READ DMA EXT
Error 603 occurred at disk power-on lifetime: 2157 hours (89 days + 21 hours)
  25 da 08 a8 37 3a 40 00      00:17:33.462  READ DMA EXT
Error 602 occurred at disk power-on lifetime: 2157 hours (89 days + 21 hours)
  40 51 08 98 e7 39 40  Error: UNC 8 sectors at LBA = 0x0039e798 = 3794840
  25 da 08 98 e7 39 40 00      00:17:29.538  READ DMA EXT
  25 da 08 98 e7 39 40 00      00:17:25.630  READ DMA EXT
  25 da 08 90 e7 39 40 00      00:17:25.630  READ DMA EXT
  25 da 08 88 e7 39 40 00      00:17:25.630  READ DMA EXT
  25 da 08 80 e7 39 40 00      00:17:25.630  READ DMA EXT
Error 601 occurred at disk power-on lifetime: 2157 hours (89 days + 21 hours)
  25 da 08 78 e7 39 40 00      00:17:25.629  READ DMA EXT
Error 600 occurred at disk power-on lifetime: 2157 hours (89 days + 21 hours)
  40 51 08 70 97 39 40  Error: UNC 8 sectors at LBA = 0x00399770 = 3774320
  25 da 08 70 97 39 40 00      00:17:21.705  READ DMA EXT
  25 da 08 70 97 39 40 00      00:17:17.795  READ DMA EXT
  25 da 08 68 97 39 40 00      00:17:17.795  READ DMA EXT
  25 da 08 60 97 39 40 00      00:17:17.795  READ DMA EXT
  25 da 08 58 97 39 40 00      00:17:17.795  READ DMA EXT
Num  Test_Description    Status                  Remaining  LifeTime(hours)  LBA_of_first_error
# 1  Short offline       Completed without error       00%       941         -
# 2  Short offline       Completed without error       00%       210         -
 SPAN  MIN_LBA  MAX_LBA  CURRENT_TEST_STATUS
    1        0        0  Not_testing
    2        0        0  Not_testing
    3        0        0  Not_testing
    4        0        0  Not_testing
    5        0        0  Not_testing
Disque /dev/sdb : 931,5 GiB, 1000170586112 octets, 1953458176 secteurs
Unités : secteur de 1 × 512 = 512 octets
Taille de secteur (logique / physique) : 512 octets / 512 octets
taille d'E/S (minimale / optimale) : 512 octets / 512 octets
Type d'étiquette de disque : gpt
Identifiant de disque : 674F14BD-2979-4FA7-ACA6-D7624D39ED29
Périphérique Début        Fin   Secteurs Taille Type
/dev/sdb1     2048 1953456127 1953454080 931,5G Données de base Microsoft
Disque /dev/sdc : 931,5 GiB, 1000204886016 octets, 1953525168 secteurs
Taille de secteur (logique / physique) : 512 octets / 4096 octets
taille d'E/S (minimale / optimale) : 4096 octets / 4096 octets
Identifiant de disque : 5821A566-C4AC-4B9B-8990-EDF132D46699
/dev/sdc1          2048     206847     204800   100M Système EFI
/dev/sdc2        206848     239615      32768    16M Réservé Microsoft
/dev/sdc3        239616 1951731485 1951491870 930,6G Données de base Microsoft
/dev/sdc4    1951731712 1953523711    1792000   875M Environnement de récupération Windows
Je n'ai pas pensé à passer -b 4096 , je ne m'en suis rendu compte trop tard.
J'ai lancé la copie avec ddrescue, j'ai copié environ 200 Gb, et comme le disque galérait pas mal, j'ai décidé de passer -i 500 Gb ce qui m'a permis de copier la deuxième moitié du disque sans problème, sauf à la fin où ddrescue m'annonce une erreur d'écriture sur le disque /dev/sdb (car il est un peu plus petit, après c'est pas grave vu que c'est visiblement une partition de récupération). Actuellement il reste 170 Gb à récupérer et ils sont regroupés au même endroit. Si besoin je peux donner le log de ddrescue.
Comment faire pour que le ddrescue n'essaie pas d'accéder à la fin du disque et comment faire pour que ddrescue récupère le plus gros des données?
Par ailleurs, j'ai regardé ce que donne testdisk sur la grosse partition, et il ne trouve qu'un dossier intel et recyble.bin . Est-ce parce qu'il manque 170 Gb? Selon testdisk la mft et la backup de la mft sont identiques.
Edit: finalement j'ai passé le paramètre -i 200GB -s 160GB et cela a permis de lancer ddrescue sur la partie que je veux, donc ça devrait être bon pour ddrescue
Merci d'avance,
Naziel
