Can't see all my partitions with Testdisk (Photorec OK)
iautran
#1 Post by iautran »
I created an IMG file with dd of an SD Card used with a specific need (a toy for my children :p)
The IMG file is correct and I managed to recover the SDCard based on that image file.
Now, I want to read the content of the SDCard but I don't manage.
When I use Testdisk, the basic scan found a little FAT16 partition with some basics PDF files (that I can copy, etc.) but the second partition is not found by Testdisk even with the "Deep search".
With Photorec, I can find quite easily some of the file in that second partition.
Someone can give me some advices on how to mount/access file on that second partition ?
Thanks a lot for your help :)
Re: Can't see all my partitions with Testdisk (Photorec OK)
If the second partition isn't deleted, TestDisk, Advanced, Boot, List.
