dd overwrite partition
xyjfroale
#1 Post by xyjfroale »
i have had an external hard drive 2TB, partition of Apple OSx
Hard drive was / is NOT encrypted
While using some software for installing data on the USB Stick,
i wrongly choosen hard drive and 'dd' process started.
I canceled it after couple seconds.
2)
Current status of the drive is like this
Disk /dev/sda: 1.8 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: M3 Portable
Units: sectors of 1 * 512 = 512 bytes
Disklabel type: dos
Disk identifier: 0x814555ba
Device     Boot Start      End  Sectors  Size Id Type
/dev/sda1        8192    92159    83968   41M  c W95 FAT32 (LBA)
/dev/sda2       92160 15126527 15034368  7.2G 83 Linux
3)
I've got other 2TB drive,
and made 'dd' copy of the overwritten one, to work saftely.
4)
current software i have is
TestDisk 7.0
PhotoRec 7.0
5) What should i do,
what i can count on?
Thank you
Re: dd overwrite partition
Using TestDisk, you can try to search for an HFS+/HFSX/HFSJ partition.
If it failed, you can use PhotoRec on [Whole Disk] to try to recover your lost data.
