Mac OS, recover from startup disk?
soonafter
#1 Post by soonafter »
I used PhotoRec successfully recently on an external drive, and now I want to use it on my internal startup disk. Is this possible? The internal disk isn't an option on the disk selection page within PhotoRec. Thanks.
Re: Mac OS, recover from startup disk?
Choose "sudo" if you don't see your internal disk (disk0).
Be carefuf to store the recovered file on another partition (or disk) than the source.
soonafter
#3 Post by soonafter »
"Sudo" doesn't appear to be an option?
https://imgur.com/b2xD0zT
soonafter
#4 Post by soonafter »
cgrenier wrote: 19 May 2020, 09:35 Choose "sudo" if you don't see your internal disk (disk0).
