FAT32 partition -- harddisk seems too small
ericjung
#1 Post by ericjung »
I have a 4 GB disk with a single FAT32 partition (trying to recover). The drive was never bootable as far as I remember; it was always external USB. I get "harddisk seems too small". I don't have a 26 TB drive :D
Screenshot
When I try to manually create the partition, TestDisk CHS limits prevent me from entering the CHS provided by TestDisk quick search - the ending cylinder value (396645) is too high for TestDisk and it wants to start at cylinder 0.
Log
Wed May 20 13:34:02 2020
OS: Linux, kernel 4.15.0-96-generic (#97-Ubuntu SMP Wed Apr 1 03:25:46 UTC 2020) x86_64
Compiler: GCC 7.2
ext2fs lib: 1.44.1, ntfs lib: libntfs-3g, reiserfs lib: none, ewf lib: none, curses lib: ncurses 6.0
/dev/sda: size       976773168 sectors
/dev/sda: user_max   976773168 sectors
Disk /dev/sda - 500 GB / 465 GiB - CHS 60801 255 63, sector size=512 - TOSHIBA MQ01ACF050, S/N:58QQT5IXT, FW:AV003D
Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 60800 255 63, sector size=4096, FW:4101
Analyse Disk /dev/sdb - 4000 GB / 3726 GiB - CHS 60800 255 63
BAD_RS LBA=1 0
 1 P EFI GPT                  0   0  2 267349  89  4 4294967295
Bad relative sector.
BAD_RS LBA=2484066679 12080435
     FAT32 LBA            154625 254 53 396645 240 50 3888050416
This partition ends after the disk limits. (start=2484066679, size=3888050416, end=6372117094, disk end=976754646)
The harddisk (4000 GB / 3726 GiB) seems too small! (< 26 TB / 23 TiB)
Re: FAT32 partition -- harddisk seems too small
Use EFI GPT instead of PC Intel.
PassNGrin
#3 Post by PassNGrin »
Did it work? It sounds similar to my problem: viewtopic.php?f=5&t=10145
In my case I did select the GPT type, but I safely exited the program before I could write the partition.
In my case, I only need to write the partition right? Then do BackupBS if the Boot sector is bad and the backup is ok or do rebuildBS if the backup boot sector is also bad?
