So after my old laptop got stuck on a booting logo and kept restarting I removed its hard drive and attached it to a new computer by using a USB-SATA-something adapter.
I couldn't access its files due to a GPT Protection Partition that apparently is larger than the actual size of the hard drive storage.
AOMEI didn't work, because of an error code 4 or I didn't have the paid version
MiniTool doesn't exactly work because I want to see the old directory structure I had on there and it only restores files without their old names.
When I used TestDisk it listed two entries for the same drive for some reason?
/dev/sdb
\\.\PhysicalDrive1
What do these mean?
I'm not sure if it's even safe to analyse for a log.
Should I just give up and use PhotoRec?
One disk is two disks?
Re: One disk is two disks?
Use either one of the listed disk.
Before I get back on topic, I just wanna say that apparently getting the SMART status isn't always reliable for checking for disk problems. I still wonder if it was a memory error though.
Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 15200 255 63
1 P MS Data 29952 244062463 244032512
2 P MS Data 244062464 244190463 128000 [Recovery]
So before I got to this point I check the program files folder in the first partition and it turned out that the last thing that was modified was some Hi-Rez Software (I guess I should never play their games again, I really put off my computer problems too late).
I forgot to check if my documents were ok though, so I quit at that point and did another analyse.
now the second analyse took longer than usual, I got a read error at 0/53/61, and I stopped the scan at cylinder 16
I can still list my files, thank goodness. Checking out the last used user (me) reveals that the last modified things were NTUSER.DAT and... IntelGraphicsProfiles? I don't remember changing any graphics setting or profile that day
Also, none of my documents are in red so they're probably fine.
My main question: That partition size looks HUGE (9 digits), and as I've said before, the disk manager showed a partition larger than the drive could hold. The example step-by-step didn't cover this, so I quit out of that part cuz I'm afraid of messing up my data. What should I do from here?
Log of first Analyse:
Analyse Disk \\.\PhysicalDrive1 - 1000 GB / 931 GiB - CHS 15200 255 63
Trying alternate GPT
check_FAT: number of bytes per sector mismatches 512 (FAT) != 4096 (HD)
file_win32_pread(596,2,buffer,1086(0/17/16)) read err: read after end of file
file_win32_pread(596,2,buffer,1087(0/17/17)) read err: read after end of file
file_win32_pread(596,1,buffer,1087(0/17/17)) read err: read after end of file
file_win32_pread(596,3,buffer,1085(0/17/15)) read err: read after end of file
file_win32_pread(596,3,buffer,1086(0/17/16)) read err: read after end of file
file_win32_pread(596,3,buffer,1087(0/17/17)) read err: read after end of file
file_win32_pread(596,2,buffer,3398(0/53/60)) read err: read after end of file
file_win32_pread(596,2,buffer,3399(0/53/61)) read err: read after end of file
file_win32_pread(596,1,buffer,3399(0/53/61)) read err: read after end of file
file_win32_pread(596,3,buffer,3397(0/53/59)) read err: read after end of file
file_win32_pread(596,3,buffer,3398(0/53/60)) read err: read after end of file
file_win32_pread(596,3,buffer,3399(0/53/61)) read err: read after end of file
NTFS at 1/220/28
filesystem size 1952260096
mftmirr_lcn 2
NTFS, blocksize=4096, 999 GB / 930 GiB
NTFS at 15192/47/24
filesystem size 1024000
mft_lcn 42666
mftmirr_lcn 2
NTFS, blocksize=4096, 524 MB / 500 MiB
file_win32_pread(596,2,buffer,244190645(15200/41/63)) read err: read after end of file
Log of second Analyse (I'm not sure why it does this twice):
NTFS at 1/220/28
mftmirr_lcn 2
NTFS at 15192/47/24
mft_lcn 42666
mftmirr_lcn 2
1 P MS Data 244062464 244190463 128000 [Recovery]
NTFS at 1/220/28
mftmirr_lcn 2
NTFS at 15192/47/24
mft_lcn 42666
mftmirr_lcn 2
NTFS at 1/220/28
mftmirr_lcn 2
NTFS at 15192/47/24
mft_lcn 42666
mftmirr_lcn 2
NTFS at 1/220/28
mftmirr_lcn 2
NTFS at 15192/47/24
mft_lcn 42666
mftmirr_lcn 2
NTFS at 1/220/28
mftmirr_lcn 2
NTFS at 15192/47/24
mft_lcn 42666
mftmirr_lcn 2
